Homebuilt Frontmount TC76 Truck Manifold Build
#83
Restricted User
times arent bad! Get that 60' down and say hello to 10's!!! i cant wait to get to that track next year..
I swaped out the 4l60e for the th400 w/brake... think that is what was causing my power loss... feels like im putting 100+hp more to the ground!!!!! Im sure its putting over 600hp to the ground now (made 528hp with slipping trans)! Gonna have to hit the dyno again to tell for sure. SOTP can be misleading sometimes, but i pulled a 7.363 0-100mph on the street today (used the hptuners timer, lol)
I see you have similar goals as me... im hoping to hit a mid 10.
#84
#85
Nice build Tally, couple of questions:
Did you need to change motor mounts with the stock k-member?? And also, do you have any more pics if your down pipe and its position, and what diameter is it?
#91
nice setup man, how much clearance do you have between the turbo and radiator with it in stock place? car has a lot more potential in it, that mph is good for mid tens, id say after you get the hang of her with the new setup itll be on kill. how does it drive on the street lag wise
