New best this weekend, getting there..
As far as the turbos being popular there is really no 'big' power blower setups that bolt on these, except for EPP's cog or a crank drive but the HP per dollar is up there pretty good compared to truck manifold/91mm setup thats for sure. If was looking to push a land yacht into the 8s or make 1000+rwhp on a dyno I'd do a turbo but I'm not so I'll stick with something simple and dead nuts reliable.
Plus since most of the fast LS cars have turbos on them, except for Ronnie Duke running in the 7s a few years ago, no one has stepped up and build a badass LS blower drag car. People copy what they see work..
As far as it unloading 30' ft out, have you lengthened the IC (torque arm down a hole) and do you got adjustable rear shocks? Tightening the rebound would help.
Yeah, there have been a few F1A cars that have done really well for HP on here, but no real stellar 1/4 mile times. There was one I recall Speedracer55XX something (sp?) that ran really well for a 6-spd at a really heavy weight. Think he went 150+ in the 1/4 at 3900#. That was impressive! But you're right, there aren't many.
Also, the Canadian guy (sorry name ?) did real well for HP and track times, can't remember the name, but he played around with cams and superchargers quite a bit.
And there is SSmokin 01 (sp?), he has been 9's with a D1, noticed that in the "Fastest 1/4 mile time in 2009" thread, can't recall any build threads, not sure on details. Anything in the single digits with the D1 is pretty damn impressive in my book.
So when are you going for more weight reduction, based on the direction you have gone with your build and your past performance in the black car, I would anticipate it is in the near future.
8 second ET's can't be too far away?Have you ordered the F1A yet?
There is some good running F1A/D1SC cars out there no doubt, but if you compare what the Ohio boys are doing with a pair of 50.00 manifolds there is no comparison really. As much as I like the prochargers even I have to admit a truck manifold setup is hard to beat if you dont mind hacking up your car a bit. 10 years ago that was a big issue, now these cars are 7-11 years old so it doesnt hurt so much to whip out the sawzall. IMO for a 9-10 second street car a procharger and a SDCE is about as simple and reliable as you can get.
I have 3 way rear shocks, not much I can do there. Only way to change IC with an uncoupled torque arm is make it longer or shorter and/or change LCA angle. The moser arm is pretty long so that inst an issue. Besides once it cools off the 60's will be back in the 1.2x range with some fresh tires, hot weather really kills the 60ft on these. Plus a lot depends on the track as well. I really havent spent much time with this car yet, been hotter then hell here lately. The car will run 9.20-9.30s as it sits in good weather on a well prepped track, been there before. Its that last couple tenths that will be tough..
F1A is only a phone call and 3-4 days away. But I really want to see what I can get out of the D1SC. Mostly because I'm cheap and its already on the car
yep still have the 'bird, with 3 kids now it just sits in the garage. I have no time for itI've been adding stuff to it for ***** and giggles while it sits, but it doesn't go anywhere.
I put it up in the air last week because I was going to change the oil, header gaskets(getting rid of my carbon fiber gaskets...seem they are leaking again) and do plugs and wires while right there too, but ended up getting the flu. Just getting over being sick so i'll pull everything off in the next day or two.
J
16psi @ 7100rpm @ 3500' DA, probably be 17.5-18 close to sea level. 7100 puts the blower at max impeller.
J
After probably 1000 passes, several dozen head gaskets, using everything from 93 pump to Q16 and three different engines I have a pretty good handle where to put the timing. Of course you can go higher, head gaskets and pistons are cheap..
Turbo car tends to create a lot of backpressure at high RPM, that backpressure is almost like EGR and cools/dilutes the intake charge preventing detonation (and reducing power of course). While its true there is less chance of detonation at higher rpm, dont ever think there isnt enough time for detonation on a forced induction car..
Good fuel system, decent fuel of known quality, plenty of injector, looking at plugs and a lot of common sense beat knock sensors anytime.
