New best this weekend, getting there..
Old Sep 11, 2009 | 12:44 PM
  #41
Superado's Avatar
11 Second Truck Club
kp...you're saying that you have basically stock timing 0 - 4500?
I've always been told that one was leaving alot on the table with a ProCharger by not adding alot more timing down low...we tried it after we got the forged motor in and actually picked up a good bit down low...
Old Sep 11, 2009 | 09:25 PM
  #42
Rickys S/C Z28's Avatar
Originally Posted by kp
Centrifugal is way different than a turbo when it comes to timing, peak torque in mine is around 5500rpm and the boost keeps ramping up quick so most of the power is concentrated between 5500-7000rpm. I have stock timing at 4500rpm as well, something you cant do with a turbo car, apples/oranges
After probably 1000 passes, several dozen head gaskets, using everything from 93 pump to Q16 and three different engines I have a pretty good handle where to put the timing. Of course you can go higher, head gaskets and pistons are cheap..
Turbo car tends to create a lot of backpressure at high RPM, that backpressure is almost like EGR and cools/dilutes the intake charge preventing detonation (and reducing power of course). While its true there is less chance of detonation at higher rpm, dont ever think there isnt enough time for detonation on a forced induction car..
once again great info man. how much compression is you motor?
Old Sep 11, 2009 | 09:48 PM
  #43
kp's Avatar
kp
No, I'm saying at 4500 I run around stock, 25* degrees or so, and thats around 5-6psi, lower than that I run more naturally. My car never sees below 4500rpm (except when its on the 2 step) during a pass and I'm not talking driveabilty tuning. Any high stalled auto isnt going to see under 4500 rpm at full throttle anyhow when you floor it so its kinda moot.
Depends a lot on your compression and camshaft, if you lower the compression and put a larger cam in you can pck up some bottom end by adding more than stock timing.
Old Sep 11, 2009 | 10:15 PM
  #44
Superado's Avatar
that's exactly it...
Old Sep 12, 2009 | 06:57 AM
  #45
98Camarod's Avatar
congrats kp, that thing sure is movin out!
Old Oct 31, 2009 | 11:07 PM
  #46
ls1CANTU's Avatar
damn, I love your car. I was looking in to buying it when you had it up for sale. If youever want to sell it, shoot me a PM. This sucker is flying. I love small cube set ups. Keep up the good work.
Old Nov 1, 2009 | 05:55 AM
  #47
EPP's Avatar
EPP
There goes another one! lol I'm sure you would be getting a very nice car if KP does sell it to you. Bob
Old Nov 1, 2009 | 09:29 AM
  #48
kp's Avatar
kp
I'll probably keep it until spring since I just winterized the boat and I need something to keep me entertained over the winter
I need to get to a 1/4 mile track again one of these days..
 Michael S. Palmer
Old Nov 1, 2009 | 02:21 PM
  #49
Bhogan909's Avatar
You need to come to Beech Bend this next weekend!
Old Nov 1, 2009 | 03:08 PM
  #50
Josh@KY-Turbo's Avatar
I would show up for that.
Old Nov 1, 2009 | 05:44 PM
  #51
kp's Avatar
kp
If the weather is good, havent been there all year
Old Nov 1, 2009 | 05:55 PM
  #52
HUNTER02SS's Avatar
Nice times Kevin. You should consider coming down to SDR on the 21st. for the MCE track day!
Old Nov 6, 2009 | 08:28 PM
  #53
kp's Avatar
kp
Actually this is a pretty old thread, been 5.80/121 recently on 275 drag radials.
https://ls1tech.com/forums/forced-in...1sc-today.html
Not sure why this thread got brought back up..
I'd love to go to SDR but 330 miles each way is a haul, I've been there a few times and like the track but its a long haul.
