My Budget TC78 in the 9's
Old Sep 9, 2009 | 06:52 PM
code4's Avatar
Default My Budget TC78 in the 9's
I have been running 9's this year with my set up. I have not figured out why my vid camera won't down load on my computer, so I used my phone to vid my TV LOL.
This run was at 12#'s, we were actually dialing it back for POA because I don't have the required stuff for 9's. Started out in the 9.8's & finally got the 10.0 we were after. They ended up picking 10.5's.
[IMG][/IMG]
Old Sep 9, 2009 | 07:00 PM
mike13's Avatar
details of the motor please.
Old Sep 9, 2009 | 07:08 PM
code4's Avatar
ls1 block, mahle 3.905 -4cc pistons & rings, eagle rods, arp head & rod bolts. The rest of the bolts are reused stockers, yes even the mains. 20K street miles on this set up.
Old Sep 9, 2009 | 07:26 PM
mike13's Avatar
who did your machine work? Also what heads?
Old Sep 9, 2009 | 08:24 PM
dudeman's Avatar
man thats haulin!! what did it dyno?
Old Sep 9, 2009 | 08:56 PM
Josh@KY-Turbo's Avatar
Been telling people along time that the TC76 and TC78 have what it takes to get there. Congrats.
Old Sep 9, 2009 | 09:50 PM
code4's Avatar
Thanks, no dyno time. I don't think it would do much on the dyno with 2.75 gears.
I just tune it on the street.
Old Sep 9, 2009 | 09:59 PM
dudeman's Avatar
what heads and cam if you dont mind?
Old Sep 9, 2009 | 10:07 PM
theblur98ss's Avatar
Awesome 9 sec build there. Kinda makes me wonder why I've spent so much money.
Old Sep 9, 2009 | 10:13 PM
00Wildcat's Avatar
build details please?
Old Sep 9, 2009 | 10:15 PM
73 nova guy's Avatar
wow and she hangs the tires with the big gears! must leave hard
Old Sep 10, 2009 | 01:42 AM
RS_SS69's Avatar
WOW impressive times, what rpm are you spinning it too? Also what trans do you have and what size tire?
Old Sep 10, 2009 | 09:21 AM
DrTurbo's Avatar
LS1TECH Sponsor
Nice! Best turbo for the money.....period!
Old Sep 10, 2009 | 01:28 PM
code4's Avatar
I have my shift lite set at 5800 IIRC. It's a turbo 400 with a brake, 28X11.5 et drags for the track.
Old Sep 10, 2009 | 01:46 PM
RS_SS69's Avatar
Are you loping off power above that or do you just not want to pull it to 65-6800rpm? Impressive times for that low gearing, real impressive!
Old Sep 10, 2009 | 02:09 PM
omore001's Avatar
I would also like to know if power is dropping above 6K on the set-up, nice runs for sure with that power glide w/ OD, JK! LoL I do know it really is a Turbo 400
Old Sep 10, 2009 | 02:24 PM
IT_SS's Avatar
[IMG][/IMG]
if you ran a 9, what the duce did the car in the right lane run? i was waiting to see you blow past em. Great run BTW, keep uo the good work
Old Sep 10, 2009 | 07:46 PM
code4's Avatar
By the Butt-o-meter it feels like I'm shifting at the correct rpm but it's never been dyno'd plus I don't run at the track much either.
I am running out of fuel injector at around 9.8's, I get into the 90% plus DC with the motoron 60's. So I'm pretty much maxed out. I could up the base FP but it's not legal to run those numbers anyway.
Old Sep 10, 2009 | 08:11 PM
71 chevy's Avatar
AFR heads iirc. dont know cam specs. must be a secret.
Old Sep 10, 2009 | 09:30 PM
98Camarod's Avatar
What's your base pressure now?
Congrat's and I loled at the video
