Another ebay start up thread
Old Sep 17, 2009 | 02:44 AM
red90cobra's Avatar
Default Another ebay start up thread
Just a stock long block with some dual valve springs. ebay kit with 4in ebay intercooler tc78 dp dumped after the k member. I cheaped it out and got i cut the front upper and lower radiator support to get the stock radiator in there with the condensor. I put two 12in pushers in front and one 16in puller in back. then put some foam weatherstriping between the two to seal the flow of air. I got the bmr turbo k in there and also modified the dp that came with the kit to go under the steering knuckle instead of over. I'm running a a1000 sumped stock tank 60lb injectors using the stock feed as the return. i built this on a budget. I will hit the dyno soon.
Heres a start up vid.
Start up vid
note i'll fix the belt. I think its got too much slackin it.
Old Sep 17, 2009 | 07:05 AM
darooke's Avatar
Nice. when are you going to tune it?
Old Sep 17, 2009 | 07:15 AM
sujomatt's Avatar
looks good dude and sounds great
Old Sep 17, 2009 | 09:42 AM
98Camarod's Avatar
It sounds quite similar to mine without the lope. Did you end up making your own power steering line and putting solid mounts on?
Old Sep 17, 2009 | 01:01 PM
red90cobra's Avatar
no it's all stock right now exept for one powersteering line where i had to make it longer.
Old Sep 17, 2009 | 01:14 PM
Super Slow SS's Avatar
which alt. relocation did you use?
Old Sep 17, 2009 | 04:54 PM
red90cobra's Avatar
I need to get the wideband figured out. It isn't working now. It was working before when i had a cam in it. Just got to figure out what the deal is. Also been raining for like two weeks straight.
it's the smokin hawk one. does it's job.
Old Sep 25, 2009 | 06:30 PM
Braunbeck's Avatar
Anymore pics of the piping and location of the downpipe? Just curious before I make the leap
Old Sep 25, 2009 | 08:51 PM
pitbull14218's Avatar
nice i would like to see some pics too!
