turbo setup ?s
Old Nov 30, 2003 | 07:00 PM
spanktu's Avatar
Default turbo setup ?s
I need to know what bracket you guys are using to
relocate the alternator to the passenger side
and where the oil pressure line for the turbo is being ran
from?.....a special fitting used on the oil pressure
gauge behind the intake?
making a custom setup so any info will be appreciated
Old Nov 30, 2003 | 09:10 PM
smokinHawk's Avatar
i got the turbotech alt relocator (for my turbotech kit) from them $300
i think there is acheaper one available, but doesnt have a tensioner on it, aka adjust by hand.
there is a cast peice above the oil filter that is tapped with a 4an fitting (or any AN fitting you use, id use a 3an if i had to do it again)
Old Dec 1, 2003 | 12:11 AM
Texas Terminator's Avatar
the piece above the filter is for oil cooler lines on the trucks and is a perfect place to tap your oil supply. your return may ba a different story if you don't have your pan tapped already.
Old Dec 1, 2003 | 12:18 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Chris from SS Racing made my custom alternator bracket, I think he would be cheaper than that.
znines@earthlink.net
Old Dec 3, 2003 | 07:26 AM
spanktu's Avatar
thanks guys
I appreciate the info!!!!!!!!
