Finally did it, I love my ProCharger, lol.
#61
130 flat is a little low for a 9.9x pass in a 800rwhp car, I would expect that out of a vig converter in a heavy/high horsepower car though. The great thing about good 60 foots is after the 1/8 it doesnt really matter if its slipping a little at the end. I can easily pull through at 7200rpm for 150+ mph, yours should have easily kept pulling as well but you have a little more weight. Generally the IATs are up pretty high and power drops off pretty good the last few hundred feet. Could have been detonating a bit as well, on a stock PCM I figure out where the IAT will be at about 800' and use the IAT temp to pull an extra degree or so out to be safe, doing that usually ups the mph a little.
FWIW with my car in 10.0 index mode on 10psi it will run 10.00 @ 134-135 with a 1.35 or so 60 foot going through a little under 6500rpm with a 3.70/28" tire, 7200rpm goes through 152 or so.
Lot depends on the track too, some will show mph higher than others. In the end it ran a 9.9x and now no one will care untill it runs an 8.9x so enjoy the moment
Next question, should I be locking up the triple disc in 3rd? PI says it's ok, Yank doesn't see how the converter could survive. Thoughts anybody?
#63
Unless you want to buy a new converter soon I wouldnt lock it up at WOT too many times, but if it were me I'd try it Be a good way to see if its either down on power or blowing through the converter but I've smoked the lockup clutches out of a couple converters with way less power than you are making.
I dont get really too paranoid about mph unless it changes a lot the same day, there are tracks around that vary 2-5mph in 1/4 mile mph. Thats why it would have been nice to see some 1/8 mile times. The air is getting better and I'm sure yours will improve soon so may as well experiment some.
#66
Just have to experiment a little, untl you get a few more passes on it and get a baseline I wouldnt change much or assume something is wrong just yet.
If the converter was locked at 6500rpm (and held) it should have been going closer to 145mph with 3.70s and 28" tires. If you have real 28" tires, 6500rpm and 130 mph will put it at 12% slippage which isnt that uncommon from some converters. I was never able to get one to lock tight, either the PCM was unlocking it for some unknown reason on mine or the clutches just couldnt hold. As stated dont lock it until 1000' or more - otherwise you will kill the lockup clutch.
#67
Well I happened to get the pedal stuck to the floor when I was logging on accident today. It looks like my shift extension (avg between 2 runs) is 281 RPM from 1st to 2nd, then 766.5 RPM. Not sure if that is good or bad, but curious on everyones thoughts.
I don't remember shifting twice, but I triple checked the spreadsheets and they say 100% throttle on both drops in RPM from the peak. It is over a period of about 4 seconds. Also, 0 knock on both runs.
#69
Hmm, interesting. The first run the 2-3 shift extension was 717, second run it was 816, if that helps. Nice part is IAT's were 104 before the 100% throttle, and 84* during the run, I love meth.
EDIT: Something else too, the car is set to shift at 6500, but on the 2-3 shift it was at 6,3XX one run, and 6,2XX on the other. Does that indicate anything to anybody? It also may not have captured that grain of detail though as far as the recording capabilities of HP Tuners goes I guess.
#70
Just some thoughts.......
If you went 134 with less power, which I think that is correct (based on what I can remember), and now you are making more power and trapping less MPH..... I would think it is the converter not holding the additional HP up top. Without track data where the tires are stuck it will be really hard to tell. BTW that 1-2 drop seems very low. Mine drops 900-1000RPM between gear changes. Right about where you would like to be.
I can understand your strong 60' though. You are stretching the converter way out with all that power and heavy mass.....Kind of hard for it to be inefficient with a 3.08 low gear and 3.70 ring and pinion in 1.1 seconds.
Yank recommended to me to not lock the converter at WOT, ever. I know PI has another thought on this, but I can't see how or why. IMO that lock up clutch in the converter cannot hold that kind of power at that weight. No way.
If you have been locking it, I'll bet it is burnt, and now you are just at the mercy of how inefficient the PI's are at big HP.
Your car should be no less than 135 in the 1/4. More like 138-140. With that kind of 60' I would expect 9.80's if it were efficient on the other end regardless of the weight, hell it is already rollin at point. The hard part with weight is getting it going, you've got that figured out.
Also, that loose converter is why you are 60' footin at 1.34. If they tighten it, that could go down. It is a compromise. That was a beauty launch BTW!
Small Procharger cars are all about first 100 ft. They leave hard characteristically, especially in a car with a 3.08 low gear and 3.70's out back. If the car sticks, it will do what yours does and run a good et.
A nice high dollar race converter that was more efficient and built specifically for your car (power/weight) would help a bunch, but that can be pricey and a crap shoot. The Yanks and PI's are off the shelf pieces that fit a wide variety of combos, definitely not the BEST choice for MAX et's at the dragstrip.
I would just be happy with it. 9's for a complete car such as yours is stout!
You can spend thousands more chasing tenths at this point. And if you don't have 300M shafts in that 4L60E you probably won't want to turn it into a track car anyway. Racing at that weight too many times will lead you into a
4L80E or TH400.
4L80E or TH400.
#73
Well it looks like something is slipping, the 281RPM "shift extension" looks like it was slip when the car was working its way up to the 2-3 shift, I knew I didn't shift twice. I'm pretty sure it isn't the tranny, I'd assume I'd have hit the limiter or blown through the shift if it was, I think it is just slowly hurting the converter.
I'll call PI this afternoon and see what's going on.
#74
I know you wanna pick up MPH, and based on that data you've collected and can give either company, I'd think they'd be able to get pretty close to right on with a converter that won't kill your 60' but hold the power up top.
#75
Unless you wanna build a new tranny to go with that new converter, I think I'd share your findings with the companies and leave it be as far as running it goes til you get in there and see how bad that disc is burnt - more debris in the fluid getting into the tranny is no bueno.
#78
Id say get it restalled and tighted for your new power to hold down low for the 60ft but still be just tight enough up top not to blow past the stall. Try that then look at the trans for a freshening.
#80
If the stall speed on the Yank isn't good enough I'll send it off in the winter to get rebuilt then let Brett go through the trans. Should have the new converter in this weekend.
