stock 6.0 turbo 600hp?
i got the lq4 6.0 with a turbo at 6 psi right now, i havent dynoed it but im planning to get close to 600hp but i wouldnt know if the stock lq4 could take that? what is the limit on boost on these motors?
i got meth but would the lq4 go up to 600 hp lelaving it all stock except for a small turbo cam? would 12 psi get you over 500? they should get over 400hp on 6 psi if im not mistaken
From what I have red alot of people who run a basic turbo setup (t70) break 600whp at this mark. I think Parishs buddy is looking to go into the 8's with a stock long block with a ls6 cam but dont qoute me on that. So depending on your turbo Id say you should be there.
Restricted User
I would love to see that but I doubt that the stock pistons could take that.
LS1Tech Sponsor
With good fuel and tuning the stock rods are the limiting factor. Pre 05's are good for about 800fwhp and the lq9's and 05' newer engines are good for 900fwhp or a little more. Afer that the rods bend/break. If the fuel is not good enough or the tuning is not on they all break shortly after 500hp though.
I am planning on 600+ on 8lbs and 700+ on 12lbs (Yes, I will test it to it's max), but my 6.0 has a custom cam, arp rod bolts, springs, pushrods, timing chain, pump and such. Also I am using the MPT76 with a Q-Trim wheel and 1.00 housing.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Remember, a LS6 cam or boost cam can yield as much as 100rwhp with no other mods and the same boost level. Search it...
98Z28CobraKiller - I think you would have easily hit the 9.xx with just a cam swap.
i dont beat the hell out of her. just a few pushes on the road, nothing that i think would hurt, say raising it to 14 psi w/meth with a real good tune would do the trick? its got the cam, springs and pushrods, are there any minor things i could change to help the motor?
What about the compression? I was told with the stock compression it was not safe to run over 8psi. That you needed to lower the compression to run higher boost and a good fuel setup.
