Help!l STS Oil Problem
Old Sep 25, 2009 | 02:32 AM
SS Ryan's Avatar
Originally Posted by flippincamaro
It probably is filling your pipes with oil aswell,Pull your charge pipe off an see if oil is in it. I was having the same problem with mine when it feeled my pipes couldnt make boost, I was running self contained oil setup, no changing my setup to feed off the engine i believe instead. Hope you figure it out soon.
thanks dude, i just ordered a Mocal Oil Cooler/Pump its supposed to scavenge a lot more better and efficient than the stock "POS" Sts pump. ill try that and then add a restrictor if that doesnt help my problems. thanks for the input
Old Sep 25, 2009 | 02:48 AM
flippincamaro's Avatar
If you do have oil in the intake pipes drain your intercooler, I had about 2 cups in mine! Still draining it, MAF hates oil on it
Old Sep 25, 2009 | 06:13 AM
SS Ryan's Avatar
will do i will disconnect the boots on it and look around for oil. i drove on it today ..pretty hard so i suspect it flowed all the way up thru my cold pipes into my IC
Old Sep 25, 2009 | 08:14 AM
Super Slow SS's Avatar
if it spooled at all, it made it to your intercooler, I had oil all around my throttle body blade in the intake, coming out of the BOV, but none puddled in the IC, but I did put about a 1/2 gallon of gas in there and swished it all around to make sure I got it all out.
Old Sep 25, 2009 | 09:59 PM
Schantin's Avatar
Yep, the Mocal is a beast compared to the stock STS pump. Much better at scavenging oil. (It's also a lot larger, so you'll have to drill a couple new mounting holes).
I saw the other comment about lack of boost. Check the MAF for oil. It's inevitable once oil gets into the intake. Oil on the MAF resistors will absolutely murder the HP. (It skews the readings of incoming airflow). Clean the intake pipes with rags (use a coat-hangar with a rag attached to a loop on the end for the long pipe along the driver door (like a rifle bore-brush). You can blow out the intercooler with compressed air. Clean the MAF resistors CAREFULLY with a Q-tip and rubbing alcohol.
Your boost + power will return after. (Been there.....done that......)
Old Sep 25, 2009 | 10:05 PM
mike13's Avatar
Been there done that on both the pump and MAF.
Old Sep 25, 2009 | 10:26 PM
Schantin's Avatar
I feel ya'. I'll be brutally honest too...... it sucks laying under the car cleaning those damn pipes too!!
Old Sep 26, 2009 | 08:32 AM
Lol, Cleaning the pipes suck! mine is sitting on the shop floor, An evryone of them have a little puddle by them! It sucks! But found the problem, My check valve was bad that I just bought the other day.
