Which Aftermarket Engine Management System?
Hey buddy I have the MSII the one that runs the coils.You could go to Jake[PBTH]or you could call him,so he could xplain to you more about it.
I'm the one that Jake call for the xtra motor...sorry I'm keeping it..good luck
I'm pretty sure that Steve (twin TC78 build in question) will be using the BS3 though.
Did you buy Darin's mustang?
If the ecu cant do it, its ***** so definately look to a different ecu. Certainly all of the ecu's Ive mentioned will do it no problems at all, and they are all fairly easy to use, and keenly priced
BS3 controls stock coils just like OEM.
still a few of us using COP...
I'm running a twin 87mm turbo set-up on my new build 427 LSX with All-Pro 6-bolt cathedral port heads, super victor, fabricated elbow, 102mm TB, 8 x 160lb Low imp injectors.
we are looking at going with the GMPP front-mount distributer drive and an MSD ignition box, not ecu controlled spark. This is really for ease of use at the track as I prefer old school, it's not a true road car but a pro-street 71 camaro.
my questions are: what fuel contoller would be best for our combination, have any of you had any experience with or know of any similar builds using the distributer drive. I was using the origional GM ECU & HP tuners with my old 346 LS1 twin-turbo set-up and found it tiresome as I'm no tech guru. I need something that will control the fuel delivery, run 8 x low imp injectors, be easy to tune, it doesn't need to control the trans and will only need to the most basic of data-logging etc. Simplicity is my main goal without going back to the dark ages and using a blow-through.
Any advice would be greatly appreciated.
