Need help picking a BOV for APS car
Old Sep 24, 2009 | 07:25 AM
jeremym's Avatar
Originally Posted by MY99TAWS6
Guy at local track was running JGS and seemed to work ok. Think gate and blow off. I like to stick to tial or turbosmart personally both top quality companies.
what do u mean ok? that is what kytp wanted use on my set up. i was going to use all turbosmart but i will them do their magic.
Old Sep 24, 2009 | 08:11 AM
Big Bird WS6's Avatar
i am going to run a synapse setup. already got them ordered.
after seeing this on youtube. hard to go different way.
Old Sep 24, 2009 | 08:12 AM
https://ls1tech.com/forums/forced-in...nline-bov.html
^^^ but this is another choose for the SD guys
Old Sep 24, 2009 | 09:32 AM
MY99TAWS6's Avatar
Hmm interesting can't see how they can possibly do anything unless the aps ones were leaking boost.
Old Sep 24, 2009 | 09:33 AM
MY99TAWS6's Avatar
I said his car seemed to run ok. He has since sold it. Josh sounds like he knows his stuff so you can go with his recommendation.I have just always had great luck with tial and turbosmart gates and blow offs.I have been into turbo cars for years with my dsms.
Old Sep 24, 2009 | 10:18 AM
i gree with you. but the $40 bosch **** ones probly do leak.
and i have seen the synapse first hand. look great and react fast
Old Sep 24, 2009 | 12:23 PM
bondosgto's Avatar
do the synapse recirculate, or do they just blow off?
Old Sep 24, 2009 | 01:12 PM
blow off.
Old Sep 24, 2009 | 01:23 PM
tomz28's Avatar
this is funny big bird i know the guy in the vette and the onwer of synapse (peter) making the vid
it looks like he does make some good BOV but i want so,ething for the top of the engine and i think his BOV are kind of big. but im planing to go down there and se what hes got
side note dude with the vette he live down here by me i try to get a race out of him he was not having it. LOL
Old Sep 24, 2009 | 02:21 PM
bondosgto's Avatar
blow off.
guess i need to look else where
Old Sep 25, 2009 | 07:55 AM
not many recirculate.
it is all personaly choice. but why you want them to recirculate?
Old Sep 25, 2009 | 10:14 AM
  #32
MY99TAWS6's Avatar
Turbosmart makes several types. Some recirc only. Some recirc and vent. Some vent only. Some places have rules about venting only. Its pretty slack in my city. They are not that loud unless of course you hit boost and really I don't hit boost much in the 99TT.
Old Sep 25, 2009 | 12:03 PM
  #33
Cobra Commander's Avatar
I have tial 50 on my 97 talon .Its top quality not that loud I don't think.
I put twin turbosmart supersonics directly in place of the aps blow offs. They are much louder and better sounding and are not recirced.They are pricey though.
I like both Tial and turbosmart both top quality. Can't really go wrong with either one.
Which supersonics did you get and where? Did you notice any difference other than the sound?
Old Sep 25, 2009 | 12:16 PM
  #34
MY99TAWS6's Avatar
I got them off ebay that was a while ago forget where. They were the turbosmart Kompact series unrecirced style. they are plug and play into my aps kit.
Noticed anything..well they are louder .I was running the aps bosch unrecirced also.
Its possible the aps leak at higher boost that might account for the one dyno of the synergy getting high numbers on dyno. There is zero other reason for one blow off to make more power than another one unless they are leaking under boost.
This problem happens with the talons..the 2nd gen stock blow off can't hold much past 10psi. the 1st gen can hold around 17psi and guys crush it to get it to hold more.
But most switch to quality aftermarket when running the big boost like 35psi.
Turbosmart also has the megasonic but its not in the kompact plug and play style.My supersonics are like 250 each.I might even get some turbosmart 38 gates they might fit better with the 4l80 swap. Its very tight in there with tials from the pics i have seen.
Turbosmart supersonic also adjust with no extra springs just simple dial. My tial you have to play with springs a bit still simple really.
I really do have to take some video of my car maybe in a few weeks since its down right now for the auto swap. Course you won't be hearing the blow offs near as much with the auto but such is life.
Old Sep 25, 2009 | 12:32 PM
  #35
Did you get the 20 mm or 25 mm ones?
What did you block off the inlet tube hole with?
Old Sep 25, 2009 | 01:59 PM
  #36
MY99TAWS6's Avatar
25mm ones. Perfect fit plug and play. Well you just adjust them with twist dials.
Old Sep 25, 2009 | 02:08 PM
  #37
bondosgto's Avatar
help with "lag". i could go away from recirculate, but im not sure how to block off the port on the intake pipeing, any ideas from the aps guys?
Old Sep 25, 2009 | 02:17 PM
  #38
MY99TAWS6's Avatar
I got block off plugs from home depot. They are for table leg protection. They fit perfect.
Rercic has nothing to do with any lag. And our cars are blow thru maf so venting not recircing is not needed. Recircing is only done for reasons of quietness . On my talon car can run a bit rich and stuff if you run non recirced since its blow thru maf.
Old Sep 25, 2009 | 03:50 PM
  #39
Z06_Fan's Avatar
MY99TAWS6,
I was curious who/what car in your area was running the JGS stuff??
Old Sep 25, 2009 | 04:52 PM
  #40
MY99TAWS6's Avatar
Mike guy with white GTA ,master power turbo ,ebay headers I think pretty sure jgs blow off and think gate?
He sold the car now so not sure who bought it or where it is.I ran decent low 11s almost a 10 at mid 120s I think for trap speed.
