What engine oil for 650+ after breakin?
Old Sep 24, 2009 | 08:30 PM
vipvegas's Avatar
Default What engine oil for 650+ after breakin?
Using Joe Gibbs on the dyno. Then what should I swap too. build in sig.
Old Sep 24, 2009 | 08:32 PM
JC70SS's Avatar
amsoil syn 10W30
Old Sep 24, 2009 | 08:35 PM
'Trust''s Avatar
Mobil 1 15w50 here.
Old Sep 24, 2009 | 08:53 PM
yessir's Avatar
anyone ever tried thid stuff http://www.toponeoil.com/oil/product...nger-cars.html
pretty much anyone who goes fast at boneville uses it
Old Sep 24, 2009 | 09:27 PM
cablebandit's Avatar
use cheap dino oil..name brand...wix filter and just change it twice as often for same price as synthetic oil
Old Sep 25, 2009 | 08:29 PM
elias_799's Avatar
Originally Posted by 'Trust'
Mobil 1 15w50 here.
15 w 50 ? i never heard of oil that viscosity, is it any good ?
i use synthetic royal purple 15w40 and for break in i used non synthetic 15w40 that i get for free at work
Old Sep 25, 2009 | 09:00 PM
'Trust''s Avatar
https://www.mobiloil.com/USA-English...1_15W-50_.aspx I love it. High HP seems to make more heat, that coupled with Mobil 1 being slightly thinner than comparable brands with the same weight really makes it a good deal for me. Bumped my idle oil pressure 3-4psi too.
Old Sep 26, 2009 | 12:54 AM
SPRAYED 01's Avatar
Rotella 5w4o synthetic. IF its okay for a high compression high boost semi truck.
Old Sep 27, 2009 | 12:42 AM
52172's Avatar
Same **** here too. I use rotella 5/40 full syn in all 3 of my vehicles best oil out there. Only costs 19 per gallon at Wally world.
Old Sep 27, 2009 | 12:51 AM
tomz28's Avatar
as long as i have 10psi of oil presure per 100hp im hp ive been runing 20w-50 Vr1
before that it was 5w-30 mobil1 but i think its all in your set up
Old Sep 27, 2009 | 01:11 AM
KILLER-LS1's Avatar
i think its 10 psi per 1k rpms....
Old Sep 27, 2009 | 01:17 AM
Avengeance's Avatar
I use Castrol GTX... with a Mobil 1 filter. I do change it often too.
IMO as long as you stay on top of your fluid changes it really doesnt matter what brand you use... however... I think the brand of filter is more important than the brand of oil. Call me crazy but thats what I believe... thats why I use a $9-10 Mobil 1 filter.
Old Sep 27, 2009 | 08:46 AM
mightyquickz28's Avatar
10w30 Brad Penn Syth/Blend and WIX filters.
http://www.bradpennracing.com/
Old Sep 27, 2009 | 09:55 PM
DeltaT's Avatar
Me too, in all my vehicles including the 13,000rpm Yamaha 450. Not so expensive that you need to feel like it has to go 10,000 miles between changes and top-notch protection.
Jim
Old Sep 27, 2009 | 10:40 PM
'Trust''s Avatar
Agreed. I don't think I make 90PSI of oil pressure, lol.
Old Oct 1, 2009 | 09:03 PM
vipvegas's Avatar
damn I missed the sell, advanced auto had gallons for 9.99 till wed. I missed out.
Old Nov 12, 2010 | 11:27 AM
vipvegas's Avatar
What you guys think about the Rotella T 20w40 and just changing it twice as often I go about 1800-2k miles per change? Or do we all concur to run the Rotella full synthetic?
I broke in with Joe Gibbs, then swapped to rotella T, have run it for past 4 changes. What you think? Total of about 8k miles with rotella T.
Old Nov 12, 2010 | 07:52 PM
jomomma's Avatar
i think the rotella deals the the extreme heat of a turbo well
Old Nov 12, 2010 | 07:55 PM
vipvegas's Avatar
went with rotella t6 full synthetic and wix standard size filter we will see how long it takes to break down and get dirty.
Old Nov 15, 2010 | 04:58 PM
Photochop's Avatar
Well...its been over a year since you started this thread....may wanna change it now
I've been using the Rotella 5/40 syn for a while now and like it a lot. Wish they made the same weight in the non syn variety, I'd run it and change it more often.
