Winter Project Help needed looking for high9s
Old Sep 29, 2009 | 11:54 PM
SLO1320's Avatar
Default Winter Project Help needed looking for high9s
Alright guys Im looking to do a project over winter. I would like it to be a high nines car but still decently street able. My set up so far Is mwc 9 inch set up with just about every suspension piece with 325 mt st rad, turbo 400 with a brake and 2 step i would like to see what would be the best set up. Would like to to do a turbo.
Old Sep 30, 2009 | 10:27 PM
SLO1320's Avatar
Alright i guess i better be more specific. Parts im probably going to start with is lq4 with a compstar 408 stroker kit, 88mm turbo, victor jr and spectrum elbow, not looking to push that much boost with out o ring the heads but not looking to do that till next year. but i still need some advise on
Which heads
What cam
Valvetrain up grades,
Which fuel up grades, (thinking two aero 1000s)
What compression ratio,
Just figure i would get an idea before i jumped in to spending money that aren't right
Old Sep 30, 2009 | 10:46 PM
venom ws7's Avatar
Which heads
What cam
With 408ci and TH400 brake 2step I'd go bigger than 88mm
""" cough """ 94mm ""cough """
AFR or TFS Heads.
Custom grind for your setup.
Dual springs, pushrods,lifter, oil pump, timing chain.
twin walbow 255 should be fine or maybe Bosch 044 but you'll need bigger rails and return system + bigger injectors.
compression from 8:5 - 10:1 depends on how much boost and what fuel are you planning to run.
OH HIGH 9S SHOULDNT BE A PROBLEM WITH THIS SETUP EVEN WITH MID BOOST.
Old Sep 30, 2009 | 11:00 PM
SLO1320's Avatar
AFR or TFS Heads.
Thanks for the input im not sure i want to do bigger then an 88 but ill have to keep it in mind. i also planned on keeping the compression ration right around 9:1. just cause i plan on a couple 15psi runs.
Old Oct 1, 2009 | 11:38 PM
2XR95Z28's Avatar
Someone point my buddy in the right direction here... Anyone have any builds that have proven themselves with track numbers?
Old Oct 1, 2009 | 11:56 PM
MelScrilla's Avatar
check out the member on here cablebandit i think his name is. He posts in the FI section all the time. I think he has a 91mm turbo on his and now he's running 9.3's and thats on a full weight t/a vert.
I dont think you need to o ring until your running well over 1000rwhp. A 408 with aftermarket heads for the thick deck, a 88 or 91mm turbo, and a good tune with your trans rear setup 9's shouldn't be any problems.
