And all i did was fix an exhaust leak !!
Got on the rollers today after several days of working out a bunch of issues with my car. (When it rains it pours) mainly it was the correction of a ridiculous leak in my driverside manifold collector. I also had to reconfigure my PCV system and replace a knock sensor, downpipe gaskets, and remove/replace spark plugs and wires.
But im here to tell you it was MORE THAN WORTH IT!
twin 57mm setup, 9.7:1 KR, boost guage showed 9 psi when i had the exhaust leak, with a afr of 11.2-11.4. Boost shows 10lbs now with afr of 11.9
I believe the timing is 14*
I also found out that im not making power after 6k so no need to rev that high. I was all and all an eventful day.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
