Breather Tanks
Old Oct 1, 2009 | 02:54 AM
SSMOKIN_Y2KSS's Avatar
Default Breather Tanks
where do you get a remotely decent sized breather tank for a pcv system with 2 -10an fittings... the only thing i have found thus far is a ridiculously huge 18inch moroso with 2 -12an fittings..... someone halppp
this things beautiful but who makes it and is it still available?
Old Oct 1, 2009 | 03:15 AM
haighter's Avatar
Check these out yo. Go to Jegs.com and enter these part numbers.
Moroso #
710-85465
710-85466
710-85500
710-63657
710-63660
710-85505
Old Oct 1, 2009 | 09:48 AM
Tricked-Out-Toy's Avatar
I believe thats a KY turbo tank.
Old Oct 1, 2009 | 07:56 PM
Tally TransAm's Avatar
i have allstar performance tank. pretty nice and only like $65
Old Oct 2, 2009 | 12:32 AM
DeltaT's Avatar
If it's not in a place that demands a metal tank, Jaz plastic breather tanks are sturdy and have 2 flat mount spots - 1 on each side - that will accept any bulkhead fitting up to -16.
Metal, the Moroso ones are nice. Pretty cheap to get an extra -12 bung TIG welded on one too, exactly where you need it.
Jim
Old Oct 2, 2009 | 01:39 AM
Jim
yah thats what i was thinking as worst case scenerio..a few of my buddies actually did that..i was just gonna try to buy one that had 2 in it already..but i may just buy one with just one bung and add a 2nd ...thanks jim...
Old Oct 3, 2009 | 07:42 AM
EPP's Avatar
EPP
You can also use Earl's fittings that are -10 hose but have -12 ends on them. Bob
Old Oct 3, 2009 | 02:37 PM
DanZ28's Avatar
Whats the point of a breather tank on a PCV system? Thought you would need a sealed puke tank for that? Or are you eliminating the PCV and putting a breather on and need two fittings on it to run one from each VC?
Old Oct 10, 2009 | 05:05 AM
thanks bob
Old Oct 10, 2009 | 01:30 PM
DanZ28's Avatar
Got no luv!
Old Oct 10, 2009 | 02:17 PM
Got no luv!
my bad....the pcv system is used to evactuate the crankcase vapors and blowby gases from inside the engine. they are usually routed into the intake manifold to be burnt again and sent out the tailpipe under stock conditions for smog/emissions reasons.when you have a situation like forced induction you produce way more blowby gases and crankcase pressure..if you dont get rid of this pressure you will blow seals out of ur engine in various places. if its a sealed container its not gonna do you much good as the pressure needs to escape. the breather tank allows the oil to fall in the tank while the gases escape in the atomosphere using gravity....
i belive this is what you were asking
Old Oct 11, 2009 | 12:53 AM
DanZ28's Avatar
No, I know what the PCV system is for and why breather tanks are needed at some point, sorry for the confusion.
When you said "where do you get a remotely decent sized breather tank for a pcv system", I was wondering why you would put a breather tank in a PCV system since it defeats the purpose of having a PCV. Now, if your taking out the PCV system and just putting in breather tank/s, then I see that. Again, I just probably mis-read your original post about breather tanks with a PCV system .
Old Oct 16, 2009 | 09:47 PM
barnat's Avatar
Default breather can
Peterson's has some nice cans and other stuff
Old Oct 17, 2009 | 09:40 PM
kkslds's Avatar
Is this tank baffled like the moroso's. I plan on using a moroso one from epp's website. If this is baffled though its price is alot better.
Old Sep 20, 2010 | 11:30 PM
bump. anyone know?
Old Sep 20, 2010 | 11:42 PM
blue00ZZleeper's Avatar
Bryce...whats going on with you car? lol
Old Sep 21, 2010 | 10:34 PM
tryin to make some power
Old Sep 22, 2010 | 04:13 PM
Nasty N8's Avatar
We offer one as well can be polished or anodized black. Billet one in the works...
Old Sep 22, 2010 | 04:39 PM
1998TA__1991RS's Avatar
u used the moroso one that comes with one -10 fitting, then just had another fitting welded on the other end
Old Feb 21, 2011 | 01:23 PM
VaderZ's Avatar
What's the part number on that one?
