Procharger plenum and meth ???
Old Oct 3, 2009 | 05:23 PM
conan's Avatar
Default Procharger plenum and meth ???
So I just got my snow performance methanol kit in the mail yesterday and I had them send me a aluminum bung for their nozzle.
I would like to place this on the opposite side as the AIT sensor. Would this be a good place to put the nozzle?
Old Oct 3, 2009 | 08:14 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I'd put it in the front of the plenum if I were you. That way, the IAT sensor will register it better. Also, that should provide the best path. Look at 'Trust's setup..
Old Oct 3, 2009 | 08:32 PM
conan's Avatar
Thanks man, are you talking something like this...
Old Oct 3, 2009 | 09:22 PM
ChevyChad's Avatar
Old Oct 3, 2009 | 09:28 PM
airforcemanss's Avatar
hey conan, what stage kit are you running?
are you running that safe injection module too? if not, does anyone on here run it in case of emergencies?http://www.snowperformance.net/product.php?pk=13
Old Oct 3, 2009 | 10:23 PM
conan's Avatar
Originally Posted by ChevyChad
Thanks for the pic, I don't think that will clear my z28 hood. I'll have to see. If not do you think option 1 in my pic would be best? That would be on the air inlet temp side.
Old Oct 3, 2009 | 10:26 PM
conan's Avatar
Here's the kit I went with http://www.snowperformance.net/product.php?pk=8
Old Oct 4, 2009 | 09:59 PM
conan's Avatar
So if I cant put the nozzle in the front because of the hood latch hook frame would this be a good place?
Old Oct 5, 2009 | 07:22 PM
conan's Avatar
TTT ^^^
Any one want to throw in their $.02 on this placement if I can't mount it in the front of the plenum.
Old Oct 5, 2009 | 09:21 PM
ChevyChad's Avatar
Can you not put it anywhere in the front? Like even if its offset to the side one way or the other? If not, I'd probably put it as shown in your last pic..
Old Oct 5, 2009 | 09:34 PM
'Trust''s Avatar
Beat me to it Chad! My nozzle doesn't stick out more than the tab does in front of the plenum, I'd be surprised if it doesn't clear.
On that note, I ordered an extra nozzle from Alkycontrol, I'll probably still plumb the front and get the center hold welded up.
Old Oct 5, 2009 | 09:45 PM
ChevyChad's Avatar
Hey man, how bout this?
Old Oct 5, 2009 | 10:37 PM
'Trust''s Avatar
I'm digging the relocate IAT idea, good call.
Old Oct 5, 2009 | 10:53 PM
ChevyChad's Avatar
I had my meth nozzle in a similar location when I had my metal plenum. Worked well
Old Oct 5, 2009 | 10:54 PM
conan's Avatar
Thanks a bunch guys. Didn't think about that option. Now 2 more questions for ya, having the meth nozzle that close to the IAT sensor won't hurt it? Where could I find a bung for the IAT sensor reloction program?
Old Oct 5, 2009 | 11:07 PM
ChevyChad's Avatar
The meth will maybe eventually eat away at the IAT sensor, but no more than if the IAT sensor was anywhere downstream of it anyways. Even if/ when it does finally render the IAT sensor bad, just get another from Oreilley, they are like what? $10.. cheap price to pay to be able to monitor your IATs after meth.
As far as relocating the IAT, for one, you can either cap the existing hole with a 3/8 NPT plug (sold at lowes or home depot), or just get it welded up. To add a bung on your pipe in the new place, you can buy a 3/8 NPT bung already to weld in, or what I did was get a spacer from lowes that is for a 1/2" bolt. It was 1" long, ID was 1/2" and OD was like either 3/4 or 7/8, somethin along those lines. Then, I cut the spacer down to about 3/8" long and tapped it with a 3/8" NPT tap, and welded it onto my pipe.
https://ls1tech.com/forums/11950864-post81.html
Old Oct 5, 2009 | 11:20 PM
conan's Avatar
Thanks a bunch chad. I would rather drill and weld on the stainless pipe that I made VS the aluminum plenum thats $250. Thanks again, chris
Old Oct 5, 2009 | 11:29 PM
ChevyChad's Avatar
No problem dude. I was sittin there wrackin my brain too on where to put it, then it hit me like a freight train if it were me, I'd probably wanna do the same and not mess up the plenum incase a FMIC is ever in the future for ya Glad I could help. Now get her done and show us pics of the finished product
Old Oct 6, 2009 | 08:50 AM
conan's Avatar
We'll do, I'm probly going to get the car out this weekend and start working on it. I'm also mounting the tank and pump in the spare tire compartment.
Thanks again chad...
