STS Upgrades
Im doing a sts rear mount on a 2000 ls1.
I have the original kit with the front mount intercooler and the stock sts PCV system and the oil return pump.
I want to make this the best an sts kit can be (without making it a front mount
) So what all parts do i need to upgrade the kit with? I was going to go with the Mocal pump but then i see people having it die after 3k and 5k miles. Any suggestions would be great.
dyno's are also deceiving, my graph drops off at about 4500rpm as does my buddies and our cars on the street pull like a fright train all the way through to 6k
http://www.youtube.com/watch?v=DR4c6qz80GA
Leading Edge Performance Rear-mount kit
STAGE-3
LS1 STS Turbo kit
42LB Green top Injectors
Autometer
Boost gauge
Wide band
Dual a-pillar pod
Custom LEP 4"intercooler (FMIC) & piping (powdercoated)
255lph Walbro/racetronix w/hotwire kit
Tial blow off valve
LEP custom turbo camshaft
LEP dual valve springs
with titanium retainers
LEP 0.80 C/M pushrods
200' DEI exhaust wrap
GT-67- or 70 Turbo upgrade
LEP ported/polished stock manifolds
Fuel pump hot wire kit
T-bolt clamp upgrade
LEP custom mods to the cold side piping
Installed & tuned
) So what all parts do i need to upgrade the kit with? I was going to go with the Mocal pump but then i see people having it die after 3k and 5k miles. Any suggestions would be great.trash there scavenge oil pump. Replace the T-tap wire into the ignition with a butt splice connection.
further details, check out my build. It is a worthy read.
I did it by welding a 4in 90 degree to the old air filter pipe (the one that puts the air filter where the drivers exhaust tip should be) and relocating the exhaust hanger mount. It worked well.
If you dont have a vented valley cover just forget that line in picture.
You could upgrade to v-band clamps so you won't have to worry about blowing out silicone adapters.
vipvegas
For pics of the air filter up in the wheel well check out the sts website for the new f body kit. You can use the original pipe by just adding an extra bend to the end that would normally attach to the turbo inlet and relocating the mounting tab.
1. Oil Catch can
2. get rid of the sts switch valve
3. change the diameter of the pipes (depending on what turbo you have)
4 get your charge to go under the axle
5. twin fuel pumps, hotwire kit
6. wrap the **** out of your exhaust
7. try to stay close to the stock manifolds and no headers
8. get intercooled
9. get a methanol injection
10. get a nice cam (Z06 or EPP I was told thunder racing has a good cam)
11. Heads (ones appropriate for you app and cam)
12. Intake (you don't want to have really any restrictions)
13. Wideband 02
is there anything missing guys I did this kinda quick
