Anyone have a LS1 383 stroker? Curious of numbers?
Old 10-07-2009, 06:33 PM
vipvegas's Avatar
Default Anyone have a LS1 383 stroker? Curious of numbers?
If anyone has a 383 stroker with turbo please post setup and numbers or dyno sheet..
Search didnt come back with much.
Thanks
Old 10-07-2009, 07:59 PM
98transguy's Avatar
numbers in sig 383 with s91 turbo
Old 10-07-2009, 08:06 PM
vipvegas's Avatar
I like!!! Shooting for 700+ with my rear mount we will see.
Old 10-07-2009, 08:07 PM
98transguy's Avatar
keep in mind #'s with small afr 205 untouched heads and baby 224/228 cam so far from optimum but still pretty nice power
Old 10-07-2009, 08:10 PM
vipvegas's Avatar
Im going together as we speak fully forged with compstar. EPP blower cam. Stock heads though. We will see.
Old 10-07-2009, 09:38 PM
1320's Avatar
Those are goooooood numbers. Im interested in hearing the whole thing. I have a 402, s91 just going together. th400, 9 inch, in a hard top 99. I have a few cams to choose from, as I havnt installed it yet, but Im thinking in the 230-240 area since it isnt really a street car. Just a streetable car that goes racing mostly.
Ive got decent heads, one flows 310 the other set flows 343 but they are probably pretty thin for boost.
Whats the specifics on your s91. compression, head flow, etc..intake
Old 10-08-2009, 07:54 AM
98transguy's Avatar
my s91 has the 1.3 a/r ratio . intake is a vic jr with intake elbow and 90mm fast tb.Numbers in sig were 20ish psi boost on c16.Compression on motor is right around 8.5-1
The flow on the heads are around 300-305.I just picked up a cam from shawn over at va speed its around the 230-240 range but ran out of money for this season.So it will be next year before it gets put in
Old 10-08-2009, 07:57 AM
vipvegas's Avatar
ok can anyone including John tell me what kind of numbers I should make.
01 WS6, GCRE built 383 stroker, TC78 rear mounted, FMIC, devilsown stg2 methanol, tial 38mm wastegate, TIAL 44m BOV, SPEC stg 3, Callies Compstar Crank & Rods, Wiseco -15cc dished, LS7 lifters, ls2 lifter trays, Stock heads, Comp Cam trunion rocker upgrade, Dual Gold Shimmed Valve Springs, Texas Speed Chromoly Pushrods, EPP FI cam@.050 232int 240exh Lift .595int .608exh Lobe Sep 115.0, Ported Melling, Rollmaster Dual Timing, ARP throughout, Racetronix 79# injectors, Dual intake 255 Walbros, stock feed and rails, SLP Y-pipe, CORSA from Y to over axle. stock rear and tranny.
Old 10-08-2009, 08:40 AM
ddnspider's Avatar
Received 1,747 Likes on 1,304 Posts
I see nothing in your post about how much boost youre planning on running.I did 600+rwhp on 7psi.
Old 10-08-2009, 01:32 PM
Johnv's Avatar
I think your rear mount will do better than my front mount and your lower compression should help you out as well, mine is 10:1.
Mine with a .96 housing 16 psi boost , meth, is making 625 rwhp.
but is choking at the top end, makes peak torque at 3400, power at 5000 rpm then falls off fast, have a bigger housing coming so will see how that goes.
Old 10-08-2009, 01:55 PM
IT_SS's Avatar
for how long?
Old 10-08-2009, 02:24 PM
ddnspider's Avatar
Originally Posted by IT_SS
for how long?
mine lived for a couple years over 600rwhp. I sold it before it broke too.
Old 10-08-2009, 04:08 PM
vipvegas's Avatar
Ill be working on rear next, so Im prepared knowing its going to go.. Thinking on a tranny from RPM stage V.
Going to boost 8-9 on street. And bring on the thunder with 15-16 on the high switch.
Goal is 700+ think its obtainable.
Quick Reply: Anyone have a LS1 383 stroker? Curious of numbers?
