What intake????
Old Oct 15, 2009 | 05:42 PM
Fireball's Avatar
Originally Posted by Auto-Teacher
Distribution of what? The injectors are spraying the fuel in the intake port? The air moves at the same speed pressurized....all runners will have the same pressure/flow at the same time...
Am I missing something? Distribution of?? Not being a smart *** just don't know what you are referring to.
air has mass and doesn't like to turn...especially at high velocity...
inner 4 cylinders were definately leaner than my corner cylinders
Old Oct 15, 2009 | 06:50 PM
RS_SS69's Avatar
Originally Posted by 1CAMWNDR
Use a Spectre or similar carb hat with an o-ring .
Stop playing with my head here man, dammit now I have to go research that **** now....
Old Oct 15, 2009 | 07:26 PM
cablebandit's Avatar
Don't know havn't dynoed yet. HKE built the engine and speced everything for the guy I bought it off of so I don't know where the power band will lie.......Probably around 5-6000 for longjevity sake.
ls6 then...cheap...fits and will support your goals
Old Oct 15, 2009 | 07:40 PM
Auto-Teacher's Avatar
Well if I use the ls6 intake I feel like all the port work Greg Good did on the heads was for nothing...
I don't know if I will be able to port match the intake. A friend of mine (who's TT car put down 75x whp) just switched to a fast 92/92. We haven't re-tuned or dynoed, But the car has definitly increased in power. I don't know, this is just what I have seen.
Old Oct 15, 2009 | 07:45 PM
I see the logic and I'll agree with that...You never stop learning.
Old Oct 15, 2009 | 07:51 PM
you just got the car....put it together with the parts you have...run it and see where its at before you go spend money. A different intake prolly will make more power...different heads will...different cam etc will. I am going 147 @ 3960 pounds with a ls6...met my goals and no need to spend more money....we are all different though
Old Oct 15, 2009 | 08:00 PM
I agree with you in the stop spending money category, however, I don't do my own tuning so it will cost me to have it tuned with the ls6 intak. If I decide to change the intake it will cost me to have it tuned again. Trying to skip that step by seeing who is using what. It is going to cost me around $600 to have it tuned and I don't want to spend that twice if I don't have to.
Old Oct 15, 2009 | 08:32 PM
C Murda's Avatar
^^^ dunno who your getting it tuned by but usually the first initial tune is 5-600$ and then anything after that you pay dyno/street tune time and a basic intake swap shouldnt throw much off...easy hour for your tuner. good luck with the build
Old Oct 15, 2009 | 08:45 PM
i bought the software and learned to tune my own. thats half the fun to me
Old Oct 15, 2009 | 09:13 PM
slow67's Avatar
Gingervitis Addict
look up extreme velocity carb hats.
Old Oct 15, 2009 | 09:18 PM
The car came with HP tuners and I am willing to learn but not on something with so many variables.....Turbos.....meth ect...I am going to start on a h/c/i car for my learning and then go from there I REALLY don't want F**K anything up. I was not aware that it would be cheaper for the second tune.
Old Oct 17, 2009 | 11:07 AM
  #32
ANYONE RUNNING a fast 92/92 intake on their Turbo setup?
