Rebuilding for boost, just a quick question(s).
Old Oct 18, 2009 | 10:19 AM
fuzzyjk's Avatar
Default Rebuilding for boost, just a quick question(s).
At min I know I need forged pistons and ARP bolts, I plan to run around 6-9lbs do I need to upgrade the short block further? I will be running a small cam and ported heads. What CR should I plan.
Is the Summit/Jegs rebuild kit worth while or would you recomend something else?
Old Oct 20, 2009 | 05:08 AM
EPP's Avatar
EPP
As a general rule we shoot for a 9.5/1 compression ratio for the ProCharger equipped engines we build.
I would replace the connecting rods, these Compstar rods have been 100% reliable for us. http://www.exoticperformanceplus.com....html?item=683
Diamond pistons have worked very well for us, we use them in most of our builds. http://www.exoticperformanceplus.com....html?item=686
Take a look at the build at this link that we did. http://www.exoticperformanceplus.com...Car.php?car=54
Give us a call today and Drew can put together a package for you.
260 244-4808. Bob
