Boost drop after cam swap question
Old Dec 5, 2003 | 05:31 PM
Ryan23silverado's Avatar
Question Boost drop after cam swap question
I went from running 5psi max boost with a 208/216 .500/.500 113lsa cam to running 3psi max boost with the new installation of the '02LS6 cam (204/218 .555/.551 117.5lsa) Is it usual to lose that much boost from a cam swap??? I was thinking boost pressure should have gone up because the decrease of valve overlap going from 113lsa to a 117.5lsa.
Even if the '02LS6 cam was a lot more efficient than my old cam at getting air in/out of the motor, I would think that a cam would only make like a half psi difference? Just to be sure, I checked everything else -no leaks and the bypass valve seems to be closing at WOT like it should.
What boost changes have you guys seen with cam swaps?
Thank you for the help.
Ryan
Old Dec 5, 2003 | 06:24 PM
ChevyNo1's Avatar
I thought a higher LSA would bleed off more boost, but I could be wrong . . .
- Dug
Old Dec 5, 2003 | 06:27 PM
CAT3's Avatar
Restricted User
Higher lsa means more cylinder pressure, but if your cam is pulling too much in, then the psi will go down, like adding cubic inches, takes more to feed it.
Old Dec 5, 2003 | 06:39 PM
MYTURBOT/A's Avatar
.050 more valve lift will move alot more air. I also think with the 113lsa cam you were getting some reversion that was letting spent exhaust gases back into the cylinder before the exhaust valve closed. Which inturn means less avalible space to fill on the next combustion stroke, higher intake pressure(Boost), higher cylinder temps and less efficent. I may be wrong but this is my theory.
Old Dec 31, 2003 | 04:47 PM
Brad-Man's Avatar
I would be interested to know if your power dropped along with the reduction in boost.
Sometimes when a process becomes more efficient, the boost level will decrease and power remain the same or better.
Seat of the pants is not a true measure....
Old Dec 31, 2003 | 04:58 PM
ChrisB's Avatar
Yep, dyno it - if the power is the same/better then you ended up with a better combination. If the power is lower then there is an issue some where.
Old Dec 31, 2003 | 05:56 PM
Noyzee's Avatar
8 second mod
The 117 is good, other mods would help answer this questin.
engin size,specs ect, But just because you swap cams means that is the reason. Ive learned my lesson!! Check all the easy **** first, it might be somthing so simple!!! hapens everytime.
The ls6 cam is a decent cam for psi aps, so id look else where, or try dyno, it might answer all.
Good luck.
Old Dec 31, 2003 | 10:44 PM
Black LS1 T/A's Avatar
Moderator
My D-1SC and 5.8/3.20 pulley combination on my stock engine was 12 PSI... 10 PSI with headers. When my 422 with heads/cam went in, it dropped down to 7 or 8 PSI.
Old Jan 1, 2004 | 06:36 AM
Twin Screw's Avatar
Mine To lost some boost after a cam change
Which is fine just put some more in and enjoy the extra power "simple"
