intercooler idea
Old Oct 18, 2009 | 10:11 PM
chvypwr31's Avatar
Default intercooler idea
i dont know much about turbo setups yet so bare with me if this sounds stupid, i was thinking in air to water intercoolers ive seen guys put ice in there and i know if you mix salt and ice its like 5 times colder if you did that in the intercooler would that make a big difference or maybe use dry ice in there.sorry if this sounds stupid. -tony-
Old Oct 18, 2009 | 10:31 PM
DeltaT's Avatar
It's all been done. The Aussies do a lot of stuff with dry ice. I've also seen combos of alcohol and dry ice, and I think acetone and dry ice. Ice and salt isn't 5 times cooler but It is a possibility as the salt lowers the freezing point of water. You'd need to protect your aluminum tanks and stuff against corrosion, but there are some (literally) cool possibilities out there. People have also done 1-shot tanks of liquid nitrogen through a regulator and then cooling an A2A IC enclosed in a box.
Jim
Old Oct 18, 2009 | 11:00 PM
The Fugitive's Avatar
how bad is the dry ice on aluminum? and where can you get some
Old Oct 18, 2009 | 11:10 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Ive also seen guys use a nitrous bottle filled with CO2 used with a bar spraying on top of A2A IC's..
Old Oct 19, 2009 | 08:07 AM
JAX04's Avatar
salt does lower the freezing point of water, but corrosion would be my biggest worry. Dry ice and or regular ice seem to be teh ticket
Old Oct 19, 2009 | 11:29 PM
DeltaT's Avatar
Anodizing the aluminum stuff is pretty inexpensive and protects against salt and alcohols no problem. Get the right lines and pump then you are all set. Most marine bilge pumps are salt water and low temp rated, and not too expensive.
Jim
