I suppose its time to make a build thread...eBay kit!
Old Jun 19, 2010 | 09:40 PM
  #381
XtremeDime's Avatar
Going on the dyno in about an hour and a half. Car is setup and ready to go, did some last minute logs and tweaks. Thanks Frost!
I cant get his ******* boost controller to work. It says 1 turn = 1 psi but Im up to 11 turns and still getting WG spring pressure(8psi)
Old Jun 19, 2010 | 09:50 PM
  #382
98Camarod's Avatar
I'm assuming you still have the ebay kit installed?
Old Jun 19, 2010 | 09:51 PM
  #383
XtremeDime's Avatar
Yep, waiting for the truck manifold parts to get here. Im going to do a before and after dyno, the only difference will be the hot piping. This way well see if the ebay is as restrictive as everyone is saying.
Old Jun 19, 2010 | 09:55 PM
  #384
-Q-'s Avatar
-Q-
Good luck man. Fingers crossed for 500hp.
Old Jun 19, 2010 | 09:57 PM
  #385
XtremeDime's Avatar
I might mix in a little race gas and see if I can get more timing...
Old Jun 20, 2010 | 06:04 AM
  #386
XtremeDime's Avatar
485 hp/492 tq on the stock clutch. Clutch is now toast though!
Old Jun 20, 2010 | 07:13 AM
  #387
98Camarod's Avatar
How much timing and boost was that?
  #388
XtremeDime's Avatar
8psi, 13* timing
Old Jun 20, 2010 | 07:41 AM
  #389
dimetweaker's Avatar
sounds like a beast! Now get that new clutch in and come take me for a ride in seward next week
Old Jun 20, 2010 | 07:52 AM
  #390
98Camarod's Avatar
8psi, 13* timing
13* is pretty conservative, were you seeing some knock?
Old Jun 20, 2010 | 08:33 AM
  #391
MUSTANGBRKR02's Avatar
NIce numbers!
Old Jun 20, 2010 | 06:29 PM
  #392
XtremeDime's Avatar
Honestly, first run, no knock. 2nd run, I fucked up and didnt even get to see the log. I was running 15* on that run. I lost 30hp so it was either the clutch slipping or getting knock retard.
We only have 90 octane here too
Old Jun 20, 2010 | 08:24 PM
  #393
Bigwill01SS's Avatar
seems like good numbers to me, with stock cam and heads. let me know when you decide to get rid of the e-bay kit i may be interested.
Old Jun 22, 2010 | 01:46 AM
  #394
XtremeDime's Avatar
Im pretty happy with em! Ill get rid of the kit for 100 + the ride($40). The crossover is dented a little and it needs a DP made.
Old Jun 22, 2010 | 01:47 AM
  #395
XtremeDime's Avatar
Since I lost the clutch, work began on getting my Textralia in. Its been collecting dust for a few months now.
Old clutch assembly
New Clutch
The old clutch has no texture left and is pretty much smooth. lol
Old Jun 22, 2010 | 01:48 AM
  #396
XtremeDime's Avatar
Some more pics
  #397
XtremeDime's Avatar
So pretty
Done. Hydros took about 45 minutes to bleed but thats what I get for replacing my ENTIRE hydraulic system. I also did the drill mod while I was at it. Car runs fine and so far, all Ive done is move it back and forth in the garage. Theres no chatter or any noises coming from the clutch so Ill say I did it right.
Overall, it wasnt that bad. Parts sucked more than others(master cylinder was the worst) combined with not knowing what I was doing, made for alot of frustration.
I need to thank Brad(Q) for helping out with everything.
Old Jun 22, 2010 | 01:55 AM
  #398
-Q-'s Avatar
-Q-
Man, I hardly did anything! Looks great though. Get those 500 miles on there!
Old Jun 24, 2010 | 12:47 PM
  #399
Big_Bird_WS6's Avatar
Originally Posted by novaflash2002
check out his website tunedbyfrost.com . nice set up man. looks to be a beast!
thank you. i hope it is. i just want to make sure i have someone tune it that knows there ****.
and i have never heard one bad thing about Frost.
plus i would like his two tune computer. one for E85 and one with stock wastegate spring and 91. ( e85 isnt everywhere yet)
Old Jul 14, 2010 | 10:36 PM
  #400
XtremeDime's Avatar
Man what an ordeal Ive had. I had a truck manifold kit on my car for about a week. I ended up taking it off because I couldnt get it to clear the front sway bar. Im gonna redo my **** over the winter so the ebay kit will have to hold me over til then.
Anyways, heres a dyno vid that I promised like a month ago:
