I suppose its time to make a build thread...eBay kit!
Old Jun 10, 2010 | 11:57 PM
  #341
XtremeDime's Avatar
In another log its showing a little rich based on your commanded AFR, so Ill have to get some better logs tomorrow. How much in kPa does 1psi of boost amount to. I know anything above 105kpa is considered boost but on 1 log it has me hitting 125kPa so Im assuming 1 kpa doesnt equal 1 psi of boost.
Old Jun 11, 2010 | 12:01 AM
  #342
Frost's Avatar
yah, OLSD mail order turbo tunes; good times
I had a cammed Fast 92 M6 today. VE and MAF both tuned with a wideband with work on the street and dyno and I'm pretty sure that it took less time from start to finish than the base calibration for yours (which may have been done from my couch).
If you get any logs you can send them over. How much boost are you making when on the gate? I ask because the timing was quite conservative to make sure that everything was going to be safe...
Old Jun 11, 2010 | 12:06 AM
  #343
Frost's Avatar
BOOST kPa PSI
0 101.325 14.7
1 108.21969 15.7
2 115.11438 16.7
3 122.00907 17.7
4 128.90376 18.7
5 135.79845 19.7
6 142.69314 20.7
7 149.58783 21.7
8 156.48252 22.7
9 163.37721 23.7
10 170.2719 24.7
11 177.16659 25.7
12 184.06128 26.7
13 190.95597 27.7
14 197.85066 28.7
15 204.74535 29.7
16 211.64004 30.7
17 218.53473 31.7
18 225.42942 32.7
19 232.32411 33.7
20 239.2188 34.7
21 246.11349 35.7
22 253.00818 36.7
23 259.90287 37.7
24 266.79756 38.7
25 273.69225 39.7
26 280.58694 40.7
27 287.48163 41.7
28 294.37632 42.7
29 301.27101 43.7
30 308.1657 44.7
Old Jun 11, 2010 | 12:09 AM
  #344
XtremeDime's Avatar
HAHA, you did a great job though!
I dont have any really useful logs, I got a couple counts here and there but nothing consistent. Currently Im running 6psi on the gate but I have a dual stage boost controller I was going to install tomorrow. Planning on running 10psi with it. Im thinking of hooking up the dual stage boost controller and 2nd pump to the same switch. Im thinking that Ill never need the 2nd pump unless Im going above 6psi and vice versa.
Thanks for the table
Old Jun 11, 2010 | 12:35 AM
  #345
Frost's Avatar
I don't like waiting on the second pump. I use a Hobbs switch that switched at 1-2 PSI to make sure that the the pump is on in plenty of time, especially for an M6 car. Let me know what you end up doing via email and I will setup your timing tables accordingly.
Old Jun 11, 2010 | 12:49 AM
  #346
XtremeDime's Avatar
I was planning on only activating the dual stage at the track or when I want to romp on it. There would be plenty of notice, I wouldnt be turning it on when Im holding at the wastegate springs 6psi. lol.
Ill email you tomorrow!
Old Jun 11, 2010 | 01:12 AM
  #347
ModularTurbo's Avatar
frost=tune master!!!!!
Old Jun 11, 2010 | 03:15 PM
  #348
XtremeDime's Avatar
I have a log of some boost, I had an oil leak issue and when I saw smoke at a stop light I stopped running it hard. The log shows me hitting 155ish kpa, which is closer to 8psi of boost, so maybe I got the wrong spring in the wastegate. If Im really running 8psi, I suppose I dont really need a boost controller :p
Old Jun 11, 2010 | 06:40 PM
  #349
novaflash2002's Avatar
amen brotha!
Old Jun 15, 2010 | 01:05 PM
  #350
XtremeDime's Avatar
Getting the car ready for the dyno! Ive had a new clutch waiting in the garage and Im looking for an excuse to put it on. Ive started collecting parts for the swap also.
I think Im going to turn the timing to 15* advanced (currently Im at 9) and see if this stock clutch will hold!
Old Jun 15, 2010 | 01:24 PM
  #351
Frost's Avatar
It was low initially to make sure you didn't have any run-away boost problems.
Send me an email with details (how many PSI you see and current WOT AFR) and I will send you an update. If you have logs with AFR in them, that's even better.
Old Jun 15, 2010 | 01:45 PM
  #352
XtremeDime's Avatar
Ya the low timing off the bat was definitely a good idea. I can be a bit eccentric at times. I sent you an email 3 days ago(junk folder maybe? lol) with some details with what I have and what I was looking to do. I dont have a ton of logs atm, its very hard to find roads around here that I can sit in boost in for long periods of time.
Im at 8psi, currently Im at 11.5-11.7, very consistently, at any point in boost. Im going to be hooking up the boost controller for 10 psi on friday though. Not in a big rush though, take your time!
If Im taking my clutch out, Im going to throw everything I can at it! lol
Old Jun 15, 2010 | 01:48 PM
  #353
Big_Bird_WS6's Avatar
Frost what do you charge for a tune? and do you have a dyno? done E85?
Old Jun 15, 2010 | 02:35 PM
  #354
-Q-'s Avatar
-Q-
Give me a shout and head out to ER if you need to get some good logs. That's where I did all of mine when I was emailing them to Steve. There's some good stretches where you should be able to pull through 4th gear safely.
And let me know when you're looking at doing that clutch...I'd like to come by and help out if I can.
Old Jun 15, 2010 | 02:45 PM
  #355
XtremeDime's Avatar
Sunday! Sunday! Sunday!Im going to be hungover but Ill power through it. lol.
I was going to come out Friday to see you, mike and this supercharged vette but no one was around.
Old Jun 15, 2010 | 03:30 PM
  #356
-Q-'s Avatar
-Q-
What is this supercharged vette you speak of? I got your email but I guess you had already headed back into town...
Did you see that Mike put his twins kit on CL?
Old Jun 15, 2010 | 03:44 PM
  #357
XtremeDime's Avatar
Theres alot of you guys out in Eagle River, doing all sorts of ****. I havent seen the vette in person but its still a work in progress too.
I just saw his twin kit for sale. Those turbos are tiny, but would be good for stock cubes. You should buy it. lol
Im going to be picking up a crossover pipe and truck manifolds soon....
Old Jun 15, 2010 | 06:13 PM
  #358
check out his website tunedbyfrost.com . nice set up man. looks to be a beast!
Old Jun 15, 2010 | 06:26 PM
  #359
CarsandWomen's Avatar
what twins kit are yall talkin bout? link plz
Old Jun 15, 2010 | 06:28 PM
  #360
XtremeDime's Avatar
Im officially kicking the ebay kit to the curb. Got a good deal on some manifolds and a crossover ~375 for the whole thing. Just need to build a downpipe which I think I can do with some of the ebay kit parts!
