I suppose its time to make a build thread...eBay kit!
Old Jan 18, 2010 | 06:59 PM
  #141
MUSTANGBRKR02's Avatar
Correct on the lines.
Old Jan 18, 2010 | 07:05 PM
  #142
XtremeDime's Avatar
Side port on the pump goes to bottom port and the top port goes to the nipple right??
Old Jan 18, 2010 | 08:28 PM
  #143
98Camarod's Avatar
You're making the lines right and not using the stock ones?
Old Jan 18, 2010 | 09:05 PM
  #144
XtremeDime's Avatar
Right, just spent 130$ on hoses and fittings @ summit. Should get em in a couple days. Still waiting on my downpipe to get welded, its been a week now....
Old Jan 19, 2010 | 01:59 AM
  #145
XtremeDime's Avatar
Wiring is pretty much done. Just need to wire up the dual stage boost controller and the toggle switch for it.
Thinking of mounting ideas for the boost controller...
Old Jan 22, 2010 | 09:00 PM
  #146
XtremeDime's Avatar
Teaser:
Old Jan 22, 2010 | 09:27 PM
  #147
-Q-'s Avatar
-Q-
You're almost done...I'm jealous.
Old Jan 23, 2010 | 08:34 PM
  #148
98camaro28's Avatar
I can't wait... and its not even my car!!! lol but really man more PICS and DEFINITELY VIDS!!!!!!!!
Old Jan 24, 2010 | 11:29 PM
  #149
1badA3Z's Avatar
Looking Good!!
Old Jan 24, 2010 | 11:48 PM
  #150
XtremeDime's Avatar
Lol thanks guys! Should be able to start it up tomorrow just got to get the right size belt and figure out all the factory wiring stuff. I do have a small update though...it looks like I might be ditching the ebay kit for a c6/truck manifold setup. A member on here has offered to have me as his guinea pig on a turbo kit that keeps a/c that he may eventually make available to everyone. Is anyone interested in buying my ebay piping?? Ill sell it for 400 shipped it will come with all the piping in the ebay kit its just wrapped pipes and coated headers. Its already been mocked up to make sure it fits also.
Old Jan 25, 2010 | 05:49 AM
  #151
stock48's Avatar
9 Second Truck Club
Originally Posted by XtremeDime
Largest single update Ive ever had on this build.
317s on
12" pushers mounted and wired(Im actually proud that I used OEM style connectors lol)
2bar MAP
all together
lots of piping wrapped
Aftermath lol
I can't believe nobody noticed the in the throttle body.
Did you have to remove the A/C with this kit?
Old Jan 25, 2010 | 03:19 PM
  #152
n20kid's Avatar
Not trying to rob the thread but what are yall doing with the air scoop on the bottom of the vehicle when u upright the radiator?? And as posted above me did u have to remove the A/C with this kit??
Old Jan 25, 2010 | 03:41 PM
  #153
XtremeDime's Avatar
Lol I know! No I retained A/C just fine
Old Jan 25, 2010 | 03:42 PM
  #154
XtremeDime's Avatar
With this kit I didnt have to stand the radiator up. I did lose the fans that were on there in favor of pusher fans though.
Old Jan 25, 2010 | 03:45 PM
  #155
I left my air damn there.
Xtreme just finish the kit you are so close and went thru to much to give it up. I have another car i can put that C6 kit on if the guy needs someone.PM me
Old Jan 25, 2010 | 05:20 PM
  #156
n20kid's Avatar
Well im doing a borg warner 74mm with a 1.32 ar i believe, and it has a much larger housings and i have to move mine forward.. But very nice build Man!! What are the pro's and con's of this kit as far as the workmanship of the pipes? Do u know what the primary tube size is on the manifolds??
Old Jan 25, 2010 | 08:04 PM
  #157
Downside is everything fits like crap. Needs alot of patience to get it in correctly. But i like mine know well when i finish tuning and getting the little things done.
Old Jan 25, 2010 | 09:00 PM
  #158
XtremeDime's Avatar
Almost done guys! Just need the correct size belt. I thought I had blown my water pump seal or the gaskets for the water pump were bad. Turns out it was leaking up by the TB coolant pipe lol! Thats the only real issue Ive had today.
Old Jan 25, 2010 | 10:36 PM
  #159
98camaro28's Avatar
Vids please!!!!!
Old Jan 26, 2010 | 12:21 AM
  #160
XtremeDime's Avatar
Lol, i have a training thing for work. im gonna stop by NAPA when I go from one spot to another. I will submit vids tho!
