View Poll Results: What intake are you using? (Forced induction)
FAST 90
7.75%
Fast 92
4.93%
LS6
41.55%
Victor JR.
21.83%
Super Victor
2.82%
Sheet metal
2.11%
Other
19.01%
Voters: 142. You may not vote on this poll
What intake are you running?
Old Sep 5, 2010 | 06:20 PM
  #61
Packy's Avatar
LS6 intake here making 550 rwhp and 510 ft lbs through a unlocked th-400.
Old Sep 5, 2010 | 11:21 PM
  #62
MaxxMitchell's Avatar
Checking in with 2 cars using the LS1 intake making 680-700rwhp.
I would like to switch to the LS6, just haven't found the right deal yet.
Old Sep 5, 2010 | 11:35 PM
  #63
Syclone354's Avatar
I have an ls1 manifold/truck tb currently. I also am thinking of going with the pro-flo. I have a fast 92mm tb and fuel rails waiting to go on whatever I end up with. I have read many other places that the pro-flo is great bang-for-buck when you have the room for it (i do no problem )
Old Sep 5, 2010 | 11:49 PM
  #64
LS2Ttype's Avatar
LS6 here 740 RWHP
Old Sep 6, 2010 | 09:01 AM
  #65
brngrhd's Avatar
of the people that listed what they have what would you run if you didn't have room restrictions? would you use the proflo if it fit? yeah yeah yeah i know ls intakes are cheaper and work but is the poflo still better?
Old Sep 6, 2010 | 09:24 AM
  #66
020NN20's Avatar
Pro Flo here, under a stock hood with just a small dimple on the outside, sitting on solid spohn mounts. Plan on running 15#+ as soon as this build is complete, should be the next couple days!!
Old Sep 6, 2010 | 09:44 AM
  #67
98Z28CobraKiller's Avatar
Restricted User
I would have the ProFlo if it fit without cutting or having to remove wipers. As far as cost, it is rather inexpensive IIRC. Under $700 w/ rails?
Old Sep 6, 2010 | 01:18 PM
  #68
brngrhd's Avatar
yes less then $600 going through summit but I'm sure you can get them even cheaper elsewhere
Old Sep 6, 2010 | 01:56 PM
  #69
stevieturbo's Avatar
There still seems to be a lack of any public testing available.
Old Sep 6, 2010 | 06:34 PM
  #70
pdasterly's Avatar
bbk and professional products, ls6 intakes were same price when I purchased
Old Sep 6, 2010 | 08:16 PM
  #71
LS2Ttype's Avatar
What is a pro-Flow intake??
Old Sep 8, 2010 | 07:01 PM
  #72
Syclone354's Avatar
http://www.summitracing.com/parts/EDL-7140/
http://www.summitracing.com/parts/EDL-71403/
Old Sep 8, 2010 | 10:21 PM
  #73
020NN20's Avatar
Originally Posted by 98Z28CobraKiller
There is one issue with the ProFlo that I forgot to mention but it's easy to remedy. Apparently a couple of the injector bungs are close to the location where the fuel rails bolt up and interfere with the fat injectors. My understanding is that clearance can be made as there is plenty of material there. If you are going to run a seimens/motron (60-80#) type injector, no action is required.
And another down fall is that you have to run the pro flo fuel rails as the bolt holes are spaced differently. However, they are the same price as any other aftermarket rails, so you can sell yours(if you have aftermarket rails) and go to summit and order the pro flo rails. I got mine under a stock hood, and plan on keeping the drivers side wiper, just have to fab a bracket.
Old Sep 9, 2010 | 10:36 PM
  #74
Syclone354's Avatar
I plan on making my fast fuel rails work on the pro-flo. Making brackets or whatever it takes. I have heard though like you said they will not just bolt up out of the box.
Old Sep 9, 2010 | 11:56 PM
  #75
HAMRHEAD's Avatar
LS2 here making 976rwhp and no problems since 2007
Old Nov 27, 2010 | 03:53 PM
  #76
fatmat80's Avatar
Back from the dead..
I am running an LS6 currently but will be going to a victor and a nw 92 this winter.
Old Nov 27, 2010 | 10:01 PM
  #77
softballnrd27's Avatar
Are LS2 intakes/heads cathedral port?
Old Nov 27, 2010 | 11:46 PM
  #78
fatmat80's Avatar
yes they are
Old Nov 30, 2010 | 01:27 AM
  #79
9sec93's Avatar
In the interest of full disclosure, MightyMouse's LS6 is modified to accept a 90mm TB IIRC. Not sure if Mike Brown's was similarly modified. There is a vendor that does it or used to do it but I can't remember who it is right now. It isn't cheap though.
pretty sure it is TPIS
Old Nov 30, 2010 | 01:37 AM
  #80
There is a drag car in Oz than has run very low 8's on a stock LS6 and Stock TB a few years ago.
Given most pipework is 3" OD, the stock TB can hardly be considered a restriction given it is pretty much 3" also.
