VA Speed 370 ci 1500hp street/strip engine
Thats the key I guess, knowing how to put it all together so you can get close to the max potential from a given turbo.
Or, is it better to build a single turbo set-up in a way where you are NOT getting close to the max output so it doesn't need to be pushed to the limit?
i use alot of tfs heads-can't say i've ever encountered this problem
Restricted User
EDIT: I should clariify that the call back that we have been waiting for is from TEA not TFS. Although they do share the same address.
Perhaps you can get a hold of them as a distributor. We have been waiting for a call back from them for a week regarding a defective set of heads that we are waiting to get replacements back on. Everytime we call we get voicemail.
most of you guys that are in this thread are running a 370 lq9. what rpm's are you guys shifting at?
in a couple yrs i will be enjoying a virginia speed double o ring block myself
congrads OP
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
