couple of supercharge questions
Old Oct 24, 2009 | 04:20 PM
G8GT7's Avatar
Default couple of supercharge questions
Hi
1.A supercharge works on a stock pulley car or any aftermarket car
2.what about a rib can I increase the rib size o whatever I want
thanks
Old Oct 24, 2009 | 05:14 PM
conan's Avatar
What blower are you talking about?
Old Oct 24, 2009 | 05:22 PM
G8GT7's Avatar
I am talking in Genaeral about supercharges
Old Oct 24, 2009 | 10:04 PM
conan's Avatar
With a procharger the 6 rib will fit on the stock crank pully, 8 rib and higher will require a aftermarket pully. The 8 rib is the most common but there are guys running 10 and 12 rib pullies.
Old Oct 25, 2009 | 05:56 AM
G8GT7's Avatar
So the main thing for the supercharge is the Pully or the Rib
Old Oct 25, 2009 | 07:00 PM
G8GT7's Avatar
any one
Old Oct 25, 2009 | 10:03 PM
blue00ZZleeper's Avatar
Yea...the more "ribs" the less belt slip...8+ rib is better and allows you to run more boost without the belt slipping as bad.
Old Oct 26, 2009 | 08:52 AM
G8GT7's Avatar
what about the pully do I need to change my stock pully if I change the Rib
Old Oct 26, 2009 | 09:34 AM
conan's Avatar
Yes if you are going to run a 8 rib or higher ( 10, 12, ect ) you will need to change the crank pully.
http://www.exoticperformanceplus.com...html?item=1899
Old Oct 26, 2009 | 09:39 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
What car are you talking about? 4th gen fbody? 5th gen fbody? c5/c6 corvette? GTO? For example, the c5/c6 corvettes use the same accessory pulleys, but the fbodies use a dedicated pulley system. Need more info to answer your question.
Old Oct 26, 2009 | 01:31 PM
G8GT7's Avatar
I have a pontiac G8 GT
Old Oct 26, 2009 | 02:29 PM
ChevyChad's Avatar
I don't know enough about those systems to answer. If you are looking at a procharger, call Bob at EPP and he can get ya squared away
Old Oct 26, 2009 | 06:52 PM
X2! LOL...dont know much about the G8's setups
Old Oct 27, 2009 | 05:11 AM
EPP's Avatar
EPP
Thanks guys, I appreciate it!
The Pontiac G8 GT ProCharger systems add an 8 rib assembly to the engine.
The blower is facing the same direction as it is on a ProCharger GTO system.
http://www.exoticperformanceplus.com...html?item=1463 Complete system
http://www.exoticperformanceplus.com...html?item=1520
Tuner kit
http://www.exoticperformanceplus.com...html?item=1541
Our fully installed price for the D-1SC system. Bob
