if you havent seen a 91mm T-4 turbo (trick or treat)
#61
Some of my intake valves ended up like upside down umbrellas....
Although I did blow the crap out of my engine at that time too...so I guess the cylinder temps were rather high
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Seat pressure combined with extreme cylinder temps I guess can only do one thing. Perhaps if its a material issue that cant be helped, ceramic coating the face of the intake valve may help stop heat transfer into the valve ?
#65
#70
figures I just spent 1500 on a new PT88...hey Jose will you do a trade in + some cash? Its kinda crazy to send in a brand new never used turb to upgrade and spend 700$ when its really only 100$ more expensive than a new one.
#71
i have been looking at making my 408lsx a 427lsx. would this 91mm t4 be the trick? i have a 88mm mid-fra. now and i am looing at making 1000rwhp, but i have been told that it cant be done with the 88mm???? it made 821 at 18psi on stock 317s, and i just got some new trickflow 235, do you think i can make 1000rwhp on the 408 with the 88mm? or go the the 91. orrr. do i have to go to a t-6?
BTW- its in a 5700lbs denali
#76
#78
It can be done. 1012rwhp we did with a customers LT1. Problem is the turbo is done and doesn't hold up as you start to over spin that unit at that point. Also that was on a 355. As the motor ci's go up the power will go down and back pressure will go through the roof.
#79
