if you havent seen a 91mm T-4 turbo (trick or treat)
#81
i have been looking at making my 408lsx a 427lsx. would this 91mm t4 be the trick? i have a 88mm mid-fra. now and i am looing at making 1000rwhp, but i have been told that it cant be done with the 88mm???? it made 821 at 18psi on stock 317s, and i just got some new trickflow 235, do you think i can make 1000rwhp on the 408 with the 88mm? or go the the 91. orrr. do i have to go to a t-6?
BTW- its in a 5700lbs denali
biggest "I" would go would be 370ish cubes with a T4.
#82
Well I plan on staying stock cubed LS2(or as close as I can) and I only want to make 1000whp on the dyno(as bragging rights) and I plan on running the car at 650-850 on the street/track
#90
#91
any clue on spool? would it be a decent choice or would there be a better option?
My car with an s374 ran 10.7@133 and some 134 traps this past weekend.. THat was with 10.9 psi and a 1.8 60ft...... damn 255 radials didnt get it done.
Shift points anywhere from 7500 to 7900 rpm.....
What is the downpipe out let size?
#92
it made 995 with worse heads and lower compression when 6 speed w/ 1psi less boost and a little less timing than now.
that exact same set up made 893 rwhp unlocked 4l80
i figure with the above changes it picked up 100rw. with the 91 i am looking for another 100 on top of that.
i still would like an inlet cover for the 91 cut down to 4" od... certainly you guys have the capability??
#93
I have talked to one of the guys at forced inductions before... I am on the waiting list for the new gtx 80mm coming out... But a 91 would be fun and different im sure....
Maybe make for some good texas mile runs, and some rediculous trapspeed 1/4mile passes.
And keep my current unit, or maybe the gtx45 for the street and some grudgeracing.
#94
#98
