38mm or 44mm TiAL Wastegate?
Old 10-30-2009 | 06:21 PM
WS6 GreeN's Avatar
Default 38mm or 44mm TiAL Wastegate?
I'm building a TT setup and am trying to decide which size WG to buy. I don't want boost creep and am looking to run between 8-10 psi or whatever it takes to make 550-575 at the wheels. Mods are in sig. Any help is apprecaited. Let me know if you need any more info.
Old 10-30-2009 | 09:43 PM
Snyper's Avatar
if your going twins youll need 2 of them. and you need to state the size of the turbos..youll probably be fine with twin 38s.
Old 10-30-2009 | 09:57 PM
FANTAZ28's Avatar
Moderator
twin 38's is fine.
Old 10-31-2009 | 12:11 AM
4SFEDZ's Avatar
ya twin 38's!
Old 11-02-2009 | 12:12 AM
WS6 GreeN's Avatar
Sorry guys, the turbos are 60 trims I believe. If nobody has had problems with boost creep with the 38s that will save me a few hundred dollars.
Old 11-02-2009 | 10:11 AM
TiAL's Avatar
i'd go with the 44's for that extra bit of low boost control
Old 11-02-2009 | 10:26 AM
DrTurbo's Avatar
LS1TECH Sponsor
38's with that setup will be fine.
