Where to buy a Tilton scavenging pump?
think this model cost around 400 something new. believe it is a tilton.
Most of the Incon owners have switched to other scavenge pumps like the Weldon 9200. You can also get the pump directly from www.flojet.com (they make the pump for tilton) for about half the cost as the tilton.
I still have the tilton pump Incon supplied and it has never seen oil. Works great as a water pump (which is what it design for)
Gary
Chris
http://www.flojet.com/prodInfoApp/se...U&typeId=FR210
Pump was originally designed as shower drain, general purpose motorhome pump. All the internals on the pump are the same. Pump is cheap to rebuild, the diaphragm cost about $16 and check valve assembly about the same, these are the only thing that should fail.
The major problem is that the gt2535 turbos only require about 1 gallon/min oil flow maximum. The way Incon has the pump setup its will flow around 2 gallons/min. which means most of the time the pump is dry. The pump can run dry but it will reduce the useful life. Most people think that the oil scavenge reserviors Incon were used because the pump could not keep up with the oil demand. Infact, for proper operation you should fill the oil scavenge tanks and oil lines to the pump full of oil, this would somewhat help the pump run longer. The best way to use this pump would be to restrict the oulet so the pump does not run dry.
The weldon 9200 which I use, is rated at 1 gpm maximum and a variable vane pump. Variable vane pump can run dry for short periods of time like a diaphragm but are rated for much longer life. They cost a lot more, but I would rather not kill my motor and turbo(s) with a cheap pump.
Hope that helps
Gary
Gary
-Geoff
-Geoff
I crunched the numbers a few years ago, before I recommended the weldon to many people. I actually recommended it long before I had my modified Incon setup up and running.
The output rate of the weldon can be adjusted by adjusting the head. Which adjusts the distance between the vane and pump housing. I have mine set at maximum flow, but several people have stated that 3/4 of maximum will also work. I have no oil issues, but I don't have a heck of lot of miles on the car, maybe 4000.
Gary
thanks a bunch,
Chris
-Jason
