Forced Inductions Parts sources
Old Nov 14, 2009 | 12:09 PM
Blevinator's Avatar
Smile Forced Inductions Parts sources
OK,
I really need some help here.
I am puchasing a turbo kit from Josh at Kentucky Turbo.
It is complete with air to water intercooler bov,etc.
What I am having trouble with, is coming up with the rest of the $$ needed for supporting mods.
This is my list so far:
Twin Walbro in tank fuel pump
317 Truck Heads
Clutch (Spec or McLeod??) Best for $$$
Mototron Injectors 60lb
Fuel Rail upgrade
Speed Inc Tu0 or TU1 cam
Diamond pistons
Callie,Eagle (or similar connecting rods)
ARP studs,etc.
Driveshaft (steel or carbon fiber)
Ford 9" rear end
Puller fans
A pillar pod (appropriate guages)
Chassis mounted torque arm (already
have sfc's,lca's,phb,etc.)
347 CI
Goal is 700RWHP
Any help on discounted parts as well as alternative recommendations is much appreciated, as well as anything I left off.
Can I re use my dual springs from my 347? They are Texas Speed dual springs that were
recently installed with my MS3 cam.
Thinking no.
Old Nov 14, 2009 | 12:37 PM
Phil99vette's Avatar
7 Second Club
Originally Posted by Blevinator
OK,
JE pistons - Virginia Speed
Callie,Eagle (or similar connecting rods) - Virginia Speed
ARP studs,etc.
Ford 9" rear end
Puller fans
have sfc's,lca's,phb,etc.) - Madman and Co
347 CI
Goal is 700RWHP
Thinking no.
Replied above
7 Second Club
If you need a radiator I've got one for sale here very soon. Double pass C & R with a fan/shroud.
Old Nov 14, 2009 | 02:54 PM
Josh@KY-Turbo's Avatar
Twin Walbro in tank fuel pump RaceTronics
317 Truck Heads Ebay
Clutch (Spec or McLeod??) Best for $$$ SPEC Twin
Mototron Injectors 60lb Racetronics
Fuel Rail upgrade Speed Inc
Speed Inc Tu0 or TU1 cam KY Turbo Inc Custom grind
Diamond pistons KY Turbo Inc
Callie,Eagle (or similar connecting rods) KY Turbo Inc
ARP studs,etc. KY Turbo Inc
Driveshaft (steel or carbon fiber) KY Turbo Inc
Ford 9" rear end KY-Turbo Inc
Puller fans Jegs
A pillar pod (appropriate guages) Jegs
Chassis mounted torque arm UMI, BMR, ect
Give me a shout bro. I can hook you up with alot of the parts you are after too. I just dont advertise that alot.
Old Nov 14, 2009 | 08:53 PM
Blevinator's Avatar
Thanks Josh!!!
Any help is appreciated!
I trust you, and am going on your recommendation!
Old Nov 14, 2009 | 08:54 PM
Blevinator's Avatar
Thanks Phil!!
Looking for a good price as parts are a little pricey!!
Did I leave any mods out??
Old Nov 14, 2009 | 08:59 PM
Blevinator's Avatar
Which guages do I need?
Triple pillar Autometer pod ok??
