What ci 370 or 383 stroker
Old 12-03-2009, 03:07 PM
khenry's Avatar
Default What ci 370 or 383 stroker
I will be soon going with a single 76mm turbo. What ci should I go with, and why (370 or 383 stroker)? Thanks!
Old 12-03-2009, 03:21 PM
BIG_MIKE2005's Avatar
I'll be goin 370 just for the simple fact that it can be cheaper to build yourself & will still make plenty of power. With the 370 you can reuse the stock crank which saves you from buying a aftermarket 4" stroke crank. Just bore the 6.0 block out .030", buy pistons/rods & your done minus your typical studs/bolting upgrades, bearing & rings.
I have heard also that a stock stroke motor will last longer than one with 4"+ crank. Not sure how much truth there is to this as I have never owned or built a stroker motor myself(yet, LOL). If some of the more experience guys would chime in on this it would be nice. This was a concern to me cause my car is & will continue to be daily driven.
I was also on the fence about 383 or 370. Since I already have a extra LS1 block I seriously thought about goin 383, but after looking around & weighing options I decided to go 370. You get the benefit of the iron block & like stated can re-use the stock crank if you buy a used short block in good condition.
Old 12-03-2009, 03:30 PM
LS1TECH Sponsor
DrTurbo's Avatar
370ci. Better compressor effc%.
Old 12-03-2009, 03:37 PM
khenry's Avatar
My plans are to use the stock block, and just send it to the machine shop for bore and stroke. Then buy the 383 rotating assembly (and shoot for 9:1 comp with the pistons) with a 228 cam and still keep my 5.3L heads from Texas speed, and still keep my ls6 intake. Any personal experience would be great! I'm sure there are several people on the fence with this.
Old 12-03-2009, 03:38 PM
LS1RedZ's Avatar
I agree with BigMike on using the stock crank versus buying a $900+ aftermarket crank. Save some money and go with a solid built 370. Spend that extra grand on something else.
Old 12-03-2009, 03:48 PM
khenry's Avatar
HP won't be different?
Old 12-03-2009, 03:49 PM
LS1TECH Sponsor
DrTurbo's Avatar
Turbo dictates the HP, not the motor.
Old 12-03-2009, 03:50 PM
LS1RedZ's Avatar
Thats what the boost controller is for!!
Old 12-03-2009, 03:55 PM
silverz28camaro's Avatar
If you plan on doing boost then the smaller 370 should be just fine, less fuel needed at cruise speed.
the smaller stroke may like higher rpms as well.
Old 12-03-2009, 04:31 PM
khenry's Avatar
Any reccomendations on turbo kit and size turbo? And what would the estimated HP be on the 370ci motor?
Old 12-03-2009, 04:39 PM
my buddy had stock truck manifolts with 10 psi on a 67mm turbo on a stock lower end ls1 (346 c.i.) made 550hp and 700ft'lbs. I think the tq was high from the smaller turbo and truck manifolds? anyway he has run a 10.4 @ 130 with that setup in a 6 speed car with full suspention 12 bolt 3.42 gears and a 28 inch mt et street.
I would imagine with a built 370 ment for boost 650 should be not problem with 12 psi or so, maybe more
Old 12-03-2009, 04:58 PM
jomomma's Avatar
well, i like my turbo`d 383 just fine! mine has an 85mm hybrid giving the 383 mouth to mouth. my tuner(frost) says im making over 700rwhp @ 15psi on my pump gas/ meth setup. we will soon find out!
Old 12-03-2009, 06:08 PM
Restricted User
98Z28CobraKiller's Avatar
Clean up your 346. Use the stock crank. Put good rods, and pistons. Use the money that you save for a set of AFR heads and stud kit. Throw in an LS6 cam. 346 is a good match for that turbo. Should have mid 9 sec potential once you put an auto in it with some high boost.
Old 12-04-2009, 01:59 PM
khenry's Avatar
Ok thanks for all the help, after researching I can get a 6.0 (370 ci) short block for $3,100 new, get a custom cam, reuse my ls6 intake, and 5.3 L heads from TSP, this gives me the added dependability of the new iron block for a little more than cleaning up my motor by leaving me the option of selling my short block somewhere. Any thoughts?
Old 12-04-2009, 02:34 PM
6techniques's Avatar
that sounds like a very good plan...now hop to it!
Old 12-04-2009, 03:00 PM
josh_z28's Avatar
What about with spay which is better?
Old 12-04-2009, 08:44 PM
khenry's Avatar
I want something that'll be there everytime I start the car, and easier on parts.
Old 12-04-2009, 10:52 PM
Mr. Sandog's Avatar
Don't neuter the motor, that's cruel.
Old 12-05-2009, 10:13 AM
IT_SS's Avatar
how much more bore on a 6.0 block for 377?
Old 12-05-2009, 01:01 PM
khenry's Avatar
I have no clue, I've been told go 370ci
Quick Reply: What ci 370 or 383 stroker
