Anyone running a turbo with nitrous
Do you know if you can put subframe connectors with the rear mount kit? I was told you cant.
I would run it just because you want to, I mean if your already running a turbo all logic and common sense arguements have already been defeated. I haven't met a person yet that could explain why they needed to turbocharge their car.
I'm going to run some nitrous on my truck just to lite the turbo off the line. I want to bracket race some next year and I need something consistent so it will 60' the same every time. So this winter I picked up a used N2O setup and a used 2 step and gonna try both of them to see how well each works for launching. Trying to brake boost the launch is very difficult to time it to get the same boost every time or to even get to the desired boost level before the light turns green. So I'm thinking with N20 I could just stage, bring it up against the converter a little bit, then launch and spray a 75 shot from 3000 to 4500 in first gear only (I have a 2800 stall converter). That should lite the turbo and launch pretty consistent every time. We'll see how well it works come spring.
But some are saying keep it simple. So I am haveing trouble makeing my mind up on how I should set it up.
anyway so what are you going to use the car for? when thinking from a design aspect i start with functionality. having the meth and nitrous to come on and off in stages does add complexity to the tune, will you be using the car at all without these features? and what will happen when they are not being used? (can you operate safely without them) .
Next i always weigh the options, I like more myself i think its possible youu may find a few ponies some where with both meth and nitrous i might even try both kits at the same time if i had this set up. When you get down to it though i think the gain will be minimal. if its a track only car why not just spray the length. It just isnt worth the complexity for the hp itself I say if its a track car,u got the juice use it. spray the length, and if u need to be slower u can always take you fanger off the button.
Lastly i consider the badass-ness, the only category i think the use of both kits would win in. If you think it looks and/or is badass enuff then just put it on there and use it anyway. Im pretty sure u can standalone a fuel system for the nitrous run it all the time with a return "wet" single fogger near TB. Most standalone pcms allow for a tune that alters the map under switched 12 I would use this during the alchohol phase. Timers and controllers for example work, like the nos progressive rate controller works just as well for both kits. The more control you give them the less you have for example in a heads up car i might see a 3 stage kit and the guy has 1 on the wheel 1 on the shifter and 1 on wot. Thats a bit exessive id say but it works for him cause he only wants to run as fast as he has to. If you use controllers for both you will just mash the throttle and have just the option of shuting it down by lifting the throttle. That is something to consider in the design of the setup.
now that i think of it you kno what u need next another turbo, and a lenco and back-half or full tube chassis, big tires... have fun
