help me with a 370 build
Old Dec 9, 2009 | 07:28 AM
00 black ss's Avatar
Default help me with a 370 build
So my original plan was to spray the car over the winter but now I'm thinking of doing a forged motor since I'm gonna be pushing the stock limits then while I'm at that why not pro charge it lol. Of coarse I'd drive the car around how it is now bc this build would take longer. So I was thinking the speed inc 370 short block with the epp cam and my ls6 intake. I'd swap stuff over like my timing chain, valve train,oil pump, underdrive pulley. Stuff like that. Then I was also thinking about getting 6,0 gm heads? Would these work? And a used d1sc on this site. My goal is 650 at the wheels starting off then once I'm used to it I could always go higher
Old Dec 9, 2009 | 09:29 AM
SELLSZ06's Avatar
that and about 12lbs should be enough for you power goals
Old Dec 9, 2009 | 03:01 PM
LS1RedZ's Avatar
Yeah those heads will work. I have a 370 with a D1SC @ 15psi right now. Made 754rwhp and 707 rwtq. So you should be fine with that setup. I am also using the EPP cam and LS6 intake with no problems. Make sure you get a large primary header (bigger than 1 3/4). Thats what is holding me back right now. Have a cut out or 2 installed too. These prochargers LOVE open exhaust!
