Do i need to retune???????????????
Old Dec 9, 2009 | 06:35 PM
SKI's Avatar
SKI
Default Do i need to retune???????????????
Will i have to retune after i install ls6 intake.? Mods stock engine,7psi procharger,38lbs injectors,safe tune from rev extreme
Old Dec 9, 2009 | 06:44 PM
6techniques's Avatar
no...but thats just an opinion.
Old Dec 9, 2009 | 09:11 PM
SKINNY69's Avatar
Even the smallest changes can throw off a tune. If you're not interested in numbers give your tuner a call and see if they'll street tune it. Street tunes usually run about half the price of dyno tuning around here.
Old Dec 9, 2009 | 09:18 PM
cracker's Avatar
Absolutely!
I mean, It really depends on who tuned your car and "how" they did it. If they tuned through the MAF you could be ok. If the MAF transfer function stays the same, A/F is good, then the meter should compensate.
At the bare minimum, you need to get it back on the dyno or data log with HP Tuners and a good wideband for verification.
But if it were my boosted car with a stock engine, I would NOT risk it.
-W
Old Dec 9, 2009 | 09:30 PM
mike13's Avatar
That's always a double edged question, it all depends on what kind of data you can collect. For example like stated above if you can datalog and have a wideband you might be good depending on what your readings are.
This is a perfect scenerio where having a good relationship with your tuner comes in handy. The tuner could probably hook up his laptop go for a quick spin and away you'd go.
