ws6 408 pt88
Old Dec 17, 2009 | 12:50 PM
LS1BLKSS's Avatar
Banned Village Idiot
that is nice man, are you going to throw some pusher fans on there? whats your fuel system gonna be?
Old Dec 17, 2009 | 01:22 PM
00bluews6's Avatar
i have a puller fan i havent even put on i am trying to get together a MagnaFuel fuel system and decided what injectors to run
Old Dec 18, 2009 | 11:57 AM
00bluews6's Avatar
does any one have a suggestion on a boost controller and two step
Old Dec 18, 2009 | 11:59 AM
00bluews6's Avatar
also need to get a wide band but with all this stuff should i go to a stand alone if so witch one
Old Dec 18, 2009 | 07:06 PM
98Z28CobraKiller's Avatar
Restricted User
I use AMS-500 + CO2 for boost control. Ligenfelter LNC-003 2-step. Innovate LM1 wideband.
Old Dec 19, 2009 | 11:15 AM
00bluews6's Avatar
im not familiar with the c02 boost control is there a kit or did u make your own co2 kit
Old Dec 20, 2009 | 12:25 PM
KCFormula's Avatar
You should take a look at theturboforums.com. Lots of good info on boost stuff there.
Old Dec 26, 2009 | 03:42 PM
00bluews6's Avatar
got some more parts for christmas hope to start on the motor so i can get this thing running
Old Dec 16, 2010 | 08:47 PM
mr_biscuitz's Avatar
Any updates to your build?
Old Dec 16, 2010 | 09:05 PM
lt1773's Avatar
nice build man
Old Dec 17, 2010 | 02:21 AM
00bluews6's Avatar
my build had to be put on hold but i did make some progress i hope to have it running by spring i plan on getting all the fuel stuff lined up and get at a BS3 and should be good to go the car is going in the shop to get the intake charge pipe re worked because of the intake change
also changed to a RMVB th400 with a chance converter
Old Dec 17, 2010 | 02:31 AM
  #32
ReApEr75's Avatar
What are the specs on the FMIC? Badass build.
Old Dec 17, 2010 | 09:46 AM
  #33
Looks really good
Old Dec 17, 2010 | 10:12 AM
  #34
LS1RedZ's Avatar
Wow looking good so far! Thing is gonna be a beast with the TH400.
Old Dec 17, 2010 | 10:29 AM
  #35
charlie_gonzales's Avatar
00bluews6...you've got a really good looking car
I really like the picture of it on the two post lift
Old Dec 17, 2010 | 05:46 PM
  #36
00bluews6's Avatar
thanks for all the compliments i just hope to get the thing running soon
Old Dec 17, 2010 | 05:55 PM
  #37
00bluews6's Avatar
inter cooler is 26.50" X 15.00" X 3.50 made by tredstone it is for 1300hp and priced right
Old Dec 17, 2010 | 09:19 PM
  #38
mad max 777's Avatar
What did the build run u? Nice setup, and that thing is gonna be a beast.
Old Dec 18, 2010 | 08:07 AM
  #39
1fast bird's Avatar
I seen earlier you wanna possibly run high 8's eventually. I think that is a reasonable goal for ya and can be done with less than 1100 rwhp......My car is close now and only has made 776 on the dyno through a th400. It scaled out at 3470 raceweight and ran a best of 9.13 @ 151 with a loose converter. No need to push it super hard for them numbers either. Good luck and nice car!
Old Dec 18, 2010 | 09:00 AM
  #40
koji777's Avatar
4" exhaust dumped at the axel? what muffler you go with? is it quiet enough to drive on the street?
