SDCE J Bracket ???
Old Dec 14, 2009 | 09:17 PM
JoeMack's Avatar
Originally Posted by flame
Here is a pic of one in the forsale section. They add the spring tensioner and bigger idler pulley. Eliminates having to self tighten your belt. Comes with a crank pulley too. https://ls1tech.com/forums/lsx-parts...oner-sale.html
Isn't there suppose to be a support brace and shims that comes with the SDCE set up?
Old Dec 15, 2009 | 12:43 AM
conan's Avatar
This is the brace that cam with my sdce set up.
Old Dec 15, 2009 | 12:49 AM
Rickys S/C Z28's Avatar
what would be great is if any one has taken any pics of the SDCE when they got it and had a pic of all the parts, maybe a step by step of how they put it on?? or a copy of the instructions?
Old Dec 15, 2009 | 12:57 AM
conan's Avatar
The J bracket just has a hole drilled/taped to 1/2 X 13 threads/inch for the bolt going through the center of the tensioner. The big thing is just the hole placement for the belt to ride straight.
Old Dec 15, 2009 | 12:59 AM
ok then that sounds easy when i do this ill post up how i did it
Old Dec 15, 2009 | 11:59 AM
flame's Avatar
The tensioner for the s10 blazer will not be an 8 rib. So you would need to buy the tensioner, proper 8 rib pulley, 8 rib idler and get it all to work.
Old Dec 15, 2009 | 08:39 PM
95lt1z383's Avatar
I just started to do this to my setup today. So far I only have the tensioner mounted and the new idler in place. Im going to try to use the idler that came with the tensioner. Its just as wide as the belt so I think as long as its spaced right it should work fine. The only thing is it might be to big. In the next few days I will make the stand off for the idler pulley on the tensioner. It dont look like its going to be all that hard to get it all done.
Old Dec 15, 2009 | 09:01 PM
JoeMack's Avatar
Keep us posted. Any pics?
Old Dec 15, 2009 | 09:17 PM
hey man PLEASE POST PICS!!!!!!!
95lt1z383's Avatar
I can take some pics when I get alittle more done on it. I looked on here and found as many pics of the setup as I could and thats what im working off right now. It will be a few days before I can get going on it again.
Old Dec 15, 2009 | 09:21 PM
ok great cant wait to see it when your done
Old Mar 3, 2010 | 01:12 PM
  #32
cals400ex's Avatar
what are the two long bolts for in the first pic? the ones i am talking about do not have a head on them.
Old Mar 3, 2010 | 01:21 PM
  #33
Floader's Avatar
those are what the stand offs thread into, you take out the bolts that hold the alt. bracket on and thread those in so they are studs.
Old Apr 6, 2010 | 09:31 PM
  #34
airforcemanss's Avatar
where is this aster guy? how much and what does his setup consist of? do you need to send him the standard j bracket?
Old Apr 7, 2010 | 12:04 PM
  #35
LS1RedZ's Avatar
His name is "Aster" on here. Ive got his bracket and it kicks ***. Comes with a brand new bracket that is machined for the tensioner and extra bolt hole for the procharger. Comes with all the standoffs and bolts and stuff. It has insane belt wrap.
Old Apr 7, 2010 | 01:37 PM
  #36
ss.slp.ls1's Avatar
Lets say you pick up the #305201 tenstioner, a pulley, and you make a standoff of the right length. Once you drill a hole to bolt on the tensioner, if only one bolt is used to secure it to the bracket, what keeps it positioned correctly and stops it from moving?
Old Apr 22, 2011 | 01:30 AM
  #37
GR8GAME's Avatar
Does the steel J bracket require that extra bracket support piece?
Old Sep 10, 2012 | 07:37 PM
  #38
1999 SS's Avatar
b u m p
Old Sep 10, 2012 | 08:20 PM
  #39
cals400ex's Avatar
i was thinking that the kits did not originally come with those supports. however, i could be wrong. the kit i bought did not have one. i called SDCE and purchased one from them.
Old Sep 10, 2012 | 11:07 PM
  #40
1999 SS's Avatar
i was just on Brute speeds website and they have the Aster J bracket and not the SDCE J bracket. is the ATI main bracket/tensioner their selling on their site for $394 similar to the SDCE bracket?
i dont mean to hijack the thread but i have a P1sc head unit that im trying to peace the rest of the kit together for my camaro and im trying to figure the best and most cost effective way of doing it.
