View Poll Results: What are you doing about crankcase ventalation on your boosted application
Just running breathers, no positive ventalation
10
62.50%
Running the stock PCV with a check valve and the PCV inlet is routed to the air filter
6
37.50%
Running a belt driven vacuum pump
0
0%
Running an electric vacuum pump
0
0%
Voters: 16. You may not vote on this poll
What are you doing about crank case ventalation
Old Dec 16, 2003 | 11:05 PM
QuickSilver2002's Avatar
Default What are you doing about crank case ventilation
This crankcase ventilation thing has been giving me fits. I had what I thought was the ultimate solution (an electric vacuum pump) but it took a puke after only a few hours of operation.
What are you guys running?
Old Dec 16, 2003 | 11:17 PM
bomax's Avatar
Stock PCV ports off valve covers Tee'd into one line, the line runs through a catch can, and then into the inlet hat on the blower.
Old Dec 16, 2003 | 11:23 PM
So you have no fresh air source? In other words, no air going into the crankcase besides blow by.
Old Dec 16, 2003 | 11:28 PM
bomax's Avatar
Correct
Old Dec 17, 2003 | 12:21 AM
Packy's Avatar
Running stock LS6 style PCV system.
Old Dec 17, 2003 | 12:48 AM
How can you be running the stock ls6 style PCV system. You must have the fresh air nipple on the TB plugged, right?.
Also, stock PCV means no ventilation under boost, right?
Old Dec 17, 2003 | 12:57 AM
buschman's Avatar
Upgraded PCV setup. Similar to bomax only I'm not running back into the inlet hat. Just venting to the atmosphere.
Mike
Old Dec 17, 2003 | 07:01 AM
StalkerLS1's Avatar
I'm setup exactly the same was as bomax182.
Old Dec 17, 2003 | 07:25 AM
MEAN LT1's Avatar
Ehh, no pcv, no tubing, just a air filter works fine.
Old Dec 17, 2003 | 09:40 AM
Shinobi'sZ's Avatar
Airfilters on both Valve Covers venting into the atmosphere.
Old Dec 17, 2003 | 12:14 PM
Phil99vette's Avatar
7 Second Club
I had 2 filters on the valve covers and with the baffles removed they puked oil. Once I added the baffles they were fine.
Phillip
Old Dec 17, 2003 | 02:35 PM
Shinobi'sZ's Avatar
Phillip
What baffles...do you have any pics????
Thanks
Old Dec 17, 2003 | 04:42 PM
MIGHTYMOUSE's Avatar
*edit* i forgot my own set up! lol
now i remember that i have the valvecovers sealed completely, the intake hole and throttlebody sealed and just a one vent out of an ls6 valley cover to catch can. .. yea that sounds better
Old Dec 17, 2003 | 04:56 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have 99-02 valve covers, and have the covers looped in back and I have an outlet hose on the front of the passenger cover that vents to open air.
I probably need that for each cover seperately.
I have a 4/6/8 caddy elec evac setup but I have not installed it and it might not pull enough. How much is needed?
Old Dec 17, 2003 | 05:37 PM
frcefed98's Avatar
two breathers one on each cover and the hose off the passenger side going to a catch can, venting to open air. I also have the LS6 valley cover with the pcv set up for the LS6, should I also tie this line into the line going to the catch can, and cover up the pcv inlet on the intake manifold?
J
Old Dec 17, 2003 | 08:29 PM
red ws6 99's Avatar
Valve covers tied together and vent lines. PCV line followed by check valve into intake manifold. Breather on passenger side valve cover. Also line going from valve cover to just behind air filter (Incon kit). I could get rid of the line from the valve cover to the air filter, not really doing much.
Gary
Old Dec 18, 2003 | 08:00 AM
White_Hawk's Avatar
Anybody try integrating the stock AIR pump system into a crankcase vent system? I heard that some of the LT1 guys do that.
-Geoff
Old Dec 18, 2003 | 08:30 AM
Justin98TransAm's Avatar
-Geoff
my 98 back two valve covers tee'd into pcv then to elbow on vortech setup, front pass side valve cover goes to catch can then to intake.
where are you guys getting your check valves?
Old Dec 18, 2003 | 09:08 AM
white hawk, if you can keep oil out of it, it works good at moving air through the motor (ventilation, not vaccum)
i ran one connected to an rpm switch on my car for 4 months maybe, but i was pulling some oil through it and i think that's what eventually killed it.
.. fwiw i did not notice a decrease in mileage or oil color/contamination or performance by leaving it off... so i left it off.
Old Dec 18, 2003 | 09:18 AM
smokinHawk's Avatar
wonder if a belt driven pump would work better then the electric one.
if i could just fit it in and keep the AC.
By Brett Foote | 2026-06-04 05:00:17
