Psj?
Old Dec 19, 2003 | 02:06 PM
BIGBOS's Avatar
Hmmm, maybe my 8 rib setup would of worked better with a bigger crank pulley, I was using a 7.85" 8 rib crank pulley from ASP, and a 3.3" Reichard racing pulley with a Dayco belt........saw 14psi then nose dived
Old Dec 19, 2003 | 02:07 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
7.85 is not far off from my 8.0 Vortech crank pulley.
Old Dec 19, 2003 | 02:08 PM
BIGBOS's Avatar
Yea, I know, I think 8.5 would of been even better......
Old Dec 19, 2003 | 03:59 PM
Evil F1 SS's Avatar
You Procharger guys should hold off a few weeks to see my results. With a f1 blower you would need a larger blower pulley. The step up is 5.X:1 so my pulley Combo would spin it close to 75k. Larger blower pulley would mean less chance of slipping.
Old Dec 19, 2003 | 04:21 PM
8seclt1's Avatar
Default that is somewhat true BUT
FYI, the step up is 5to1.... and that is great BUTTTTTTTT..... have you ever tried to start out riding a 10speed in 10th gear? with that great of a step up, it becomes much more difficult turn the wheel (impellar).. this is the reason why a procharger blower requires considerably more hp to turn than an equivalent vortech blower..just my $.02
Old Dec 19, 2003 | 06:29 PM
Evil F1 SS's Avatar
how so? 3.08:1 rear end creates more load on a motor at start than a 4.10:1 would. The prochargers should be easy to get spinnig and taxing on the biger end. the vortechs the oposite.
Old Dec 19, 2003 | 06:48 PM
XLR8NSS's Avatar
Adkoonerstrator
The rear gear in a car is a step down(small gear driving a big gear). A blower is the exact opposite.
Old Dec 19, 2003 | 07:40 PM
8seclt1's Avatar
thank you xlr8nss...
and my scenario of a 10speed is similar to a blower... big gear driving a little gear
Old Dec 20, 2003 | 02:33 AM
BIGBOS's Avatar
Yea, they do suck up quite a bit of power......
It would be a good thing to run a bigger blower pulley with the bigger crank pulley, then there won't be a lot of slip.......
I plan on an F1 in the future with a Intercooler setup similar to PSJ's.........
Old Dec 20, 2003 | 12:01 PM
Evil F1 SS's Avatar
Same here, but first ill see what the d1 will make. then a f1 then a front mount IC.
Old Dec 21, 2003 | 06:42 PM
BIGBOS's Avatar
I also plan on pushing the D-1SC to its limits.....
Old Dec 21, 2003 | 07:51 PM
  #32
Evil F1 SS's Avatar
Bigbos, your local..... I would like to check out your ride sometime.
Off topic - I just set my budget for my 03 Cobra and it just kinda hits me that Ill put down the same or better numbers for 10 to 15 grand less. But by July I'll be able to breeak down cost to modify each of the two cars.
Old Dec 23, 2003 | 10:46 PM
  #33
BaddMood's Avatar
Hey PSJ
Hope you get it all figured out soon. Doesn't sound like your having fun with this blower deal. What kinda times are you expecting out of your beast?? Just a thought but why not big cube spray?? what kind of power did you make with your old combo??Been off line for a while bring me up to speed.
thanxs Baddmood
Old Dec 24, 2003 | 10:15 AM
  #34
BaddMood's Avatar
wow thanxs for the response PSJ
Old Dec 25, 2003 | 02:07 PM
  #35
BIGBOS's Avatar
Evil I would like to see your ride as well............
I still got my car out for now, just with out the supercharger attached getting around 6 miles to the gallon with a washed out tranny and a supercharger tune.........
Old Dec 27, 2003 | 03:26 AM
  #36
Evil F1 SS's Avatar
Bigbos, My car is still at speed inc. It should be there for two more months.
Old Dec 27, 2003 | 07:56 PM
  #37
LS1Tech Co-Founder
I am up in Western Michigan and have had limited internet access.
Dyno update: 560rwhp, 14psi, T400, 7000 stall.
Yup we are making 14 lbs of boost with a 7000 stall.
I will change the stall and then we will redyno.
We think mid 600's rwhp on a dynojet is for sure, it's only going to go up with a 4000-5000 true stall. I'm thinking 4000 stall right now.
Old Dec 28, 2003 | 01:59 AM
  #38
NA$TY-TA's Avatar
Sounds good PSJ. Keep us posted. What brand converter is in your 400??
Kyle
Old Dec 28, 2003 | 09:31 PM
  #39
LS1Tech Co-Founder
I have a TCS Phoenix Super Pro, it's a 9" converter that was supposed to be around 5000 but it flashes to 7000.
Old Dec 29, 2003 | 12:09 PM
  #40
BIGBOS's Avatar
Need to tighten that puppy up.........good to see your making progress
