Twin T70's or a single PT88/GT88???
i would consider getting an aftermarket radiator that is shorter and not as wide, but an thicker or so, so you can lean it forward and tuck it under the front support. This will open up lots of room to work, and may help fit that big *** turbo a little better. Im sure you saw BLwnLS1s build over on ls1gto.
