Any idea's on which piston to run? LS3 block,stock stroke,6.125 rods,4.065 bore, AFR225 heads 64cc chamber's. Want to be 9.0 to 9.5 to 1 on compression. Will run 10 to 12 psi, 76mm turbo.
Yeah chase I had told your dad you would want a 15-20cc dished piston. The CR calculator is easy to find just do a google search if you want one to help you out.
