Boost problem, cutting out real bad, need help!!!!!!!!!!!
Old Jan 3, 2010 | 02:08 PM
99CAMMEDSS's Avatar
Default Boost problem, cutting out real bad, need help!!!!!!!!!!!
Well long story short i put a Aem Tru boost controller on the car to bump the boost from 6 pounds to around 8-9 pounds of boost, it runs great on 6 pounds it doesn't cut out going into boost its real smooth, anyways i took it to get re tuned and dyno'd on 8-9 pounds well anything over 6 pounds of boost it starts to cut out real bad, im stumped i put new tr6 plugs and gapped them to .030, put some different plug wires, checked all the grounds and couldn't find anything, any help or opinions would be great thanks for any help!!!!!!!! All the specs to the car are in sig....
Old Jan 3, 2010 | 02:29 PM
HUNTER02SS's Avatar
Cutting out as in like a mis-fire? If you have to much fuel it will mis-fire as well. What is your Fuel pressure under boost. You have enough fuel pump for the extra HP? Running lean will mis-fire and pop as well.
Old Jan 3, 2010 | 02:43 PM
99CAMMEDSS's Avatar
Yes you could call it a mis-fire, I have a racetronix fuel pump with the hot wire kit, on the dyno the fuel pressure was dropping about 8-10 pounds he said thats a big drop but should be able to get it to run fine on 8-9 pounds not sure if he was right or not.
Old Jan 3, 2010 | 02:51 PM
1BAD_LS1's Avatar
Restricted User
its fuel or spark.....
have your tuner check spark dwell settings.... gap your plugs a little smaller... check connectors for coil power...
check fuel pressure during the runs... make sure your injectors are large enough (check duty cycle)
also what valvesprings are you running???? could it be valvefloat???
Old Jan 3, 2010 | 02:59 PM
HUNTER02SS's Avatar
Your fuel pressure shouldn't drop under boost. Dropping 10psi. is alot.
It should stay the same, or go up per lb. of boost with a Boost regulated fuel pressure regulator. Do you have a Fuel pressure regulator? Which fuel pump you running?
Old Jan 3, 2010 | 03:03 PM
99CAMMEDSS's Avatar
He tried for hours to get it to run right, and finally said that there is something wrong he said that the spark kept cutting out at the higher boost level, ive checked all connections to coils and they seemed fine, fuel pressure was dropping around 8-10 pounds wot, and i have 60 lbs injectors, Its got Partiot "Gold" .650" Lift Dual valve Springs.
Old Jan 3, 2010 | 04:50 PM
TX RED's Avatar
I would say drop a second pump and buy a fuel regulator
Old Jan 3, 2010 | 05:52 PM
Area 51's Avatar
sounds too rich. whats the wideband saying?
Old Jan 3, 2010 | 05:58 PM
MUSTANGBRKR02's Avatar
If he is dropping 8-10 lbs. of fuel pressure i would say too lean.
Old Jan 3, 2010 | 08:22 PM
99CAMMEDSS's Avatar
Well for some reason it looks like the wideband shows very rich 10.0 and it maxes out on the rich side of the guage, going up the street my friend said he saw flames coming out of the exhaust when it started to misfire, then i drove back by were it started to misfire and there were black exhaust marks on the asphalt from the exhaust dump, so i guess that would mean very rich right?
Old Jan 3, 2010 | 08:53 PM
Area 51's Avatar
Yeah, I'm with you man but if it's really rich, like 8:1, then a 10 psi cut isn't going to do enough.
Old Jan 3, 2010 | 08:54 PM
IT_SS's Avatar
lol, sounds like a supra
Old Jan 3, 2010 | 08:56 PM
Area 51's Avatar
Yep. 10:1 is probably the bottom limit of the sensor so I bet it's richer than that. lean it out some and you'll see the money.
Old Jan 3, 2010 | 09:33 PM
black98ws6ta's Avatar
Sounds like the opposite to me. The tuner could have too much fuel commanded, that it is blowing out the spark, and dropping fuel pressure.
Old Jan 4, 2010 | 09:11 AM
charcold-bowtie's Avatar
Assuming a f-body tune is like a truck.... I would say it could be burst knock in the tune. Sounds very familiar with what my truck did the first time I went from 6lbs up to 9. Just zero out the table in the tune. My FP would drop several psi, like 8, during a WOT run. No its not really ideal, and is now fixed, but it doesnt mean its going to go lean. I was OLSD as well.
Old Jan 4, 2010 | 11:41 AM
If the car was fine at 6 psi, and you went to retune for higher boost and the air fuel reads 10.0-1, you need to take some fuel out of it! That is definitely part of, if not all of the problem.
Old Jan 5, 2010 | 10:09 AM
redfirebird's Avatar
personally i think you are grtting a false rich reading with that being said you have a problem you shouldn't lose fuel pressure when your adding boost the car is going LEAN !!!!!
Old Jan 5, 2010 | 10:24 AM
HUNTER02SS's Avatar
I agree. Losing fuel pressure under boost is not a good thing.
Old Jan 5, 2010 | 10:40 AM
Any car with a stock style fuel system is going to lose some fuel pressure, but keeping it at a minimum is good. Another fuel pump in the tank triggered to come on under boost would help.
at 10.0-1 on the dyno the car should spit some black smoke, were you able to tell anything there?
Old Jan 5, 2010 | 02:53 PM
HUNTER02SS's Avatar
If you are losing fuel pressure, your fuel pump is not keeping up. Compensating for this in the ECU is a bandaid fix to a problem that needs to be fixed. Reading rich can be a result of the misfire, but if the cylinder is completely dead, it can read a lean condition if to much unburnt fuel is passed thru.
