exhaust size
Old Jan 6, 2010 | 06:29 AM
forcd ind's Avatar
Default exhaust size
i ran a 2.5" Flowmaster setup all last year with the Procharger/6.0, but now i have the stroker, AFR 225 heads, EPP cam, wonder if a switch to 3" would yield much-its in an A body, true dual exhaust
not sure what size the Vette/Camaro guys are running
Old Jan 6, 2010 | 07:14 AM
93formto98T/A's Avatar
Did you change the pulleys on the procharger? If not then you'll be making less boost with the new setup and close to the same power levels as before. If you're pullying up then definitely go bigger on the exhaust. What power were you putting down? Which procharger?
Old Jan 6, 2010 | 08:12 AM
forcd ind's Avatar
i run a D1SC, went to a smaller drive pulley, i see about 3 lbs more in the hat
(i run a blowthru carb)
i had a little over 500 to the rear wheels before the new engine
Old Jan 6, 2010 | 09:52 AM
hellbents10's Avatar
LS1Tech Sponsor
It will help yes, also the flowdisaters are making matters worse. Should make great power with the new setup.
Old Jan 6, 2010 | 11:12 AM
Definitely do a 3" or even 3.5" with a bullet (straight through) type muffler and no cat if possible. I'm running 3.5" duals with my procharger setup
