any blow thru carb guys here
is there anyone around on here that has a blow thru carb setup on anything 5.3 6.0 6.2.stock, built ect.. have a few questions for ya if you guys could help out. thanks
you dont happen to run the msd 6ls2 box do you ?if so i was curious how you set the timing for the boost. seems on my motor it runs the best with the "curve3" timing chip and the max timing on that chip is 23 degrees. i just cant see pulling out whatever timing for lets say 7 lbs just dont add up to me
