A few questions about supercharger
Old Jan 13, 2010 | 03:15 PM
G8GT7's Avatar
Default A few questions about supercharger
Hi
1.how can I raise the boost of my supercharger from 6psi to 8psi
2.the supercharger works by the belt or the pulley
thanks
Old Jan 13, 2010 | 05:50 PM
Jontall's Avatar
1. smaller pulley
2. the belt drives the pulley that turns the super charger.
Old Jan 14, 2010 | 06:18 AM
G8GT7's Avatar
what about the Rib I think going for a higher boost needs a bigger Rib correct me if I am wrong
Old Jan 14, 2010 | 08:23 AM
BIG_MIKE2005's Avatar
As stated you'll need to swap the pulley on the head unit. If your running a 6-rib kit you would benefit from goin to the 8-rib upgrade.
Old Jan 14, 2010 | 09:05 AM
G8GT7's Avatar
I am asking in general if I am going for a higher boost I just need to swap my pulley no need to change the Rib size ?
Old Jan 14, 2010 | 09:12 AM
Well if your just wanting more boost you can do that without upgrading to the 8-rib kit but your asking for belt slip. Hence why most guys ditch the 6-rib in favor of the 8-rib to help prevent belt slip.
Old Jan 14, 2010 | 09:34 AM
Superman09's Avatar
LS1Tech Sponsor
To raise boost you will need to change the size to a smaller pulley. By doing this it is spinning faster with less wrap area hence why you may want to go to the 8 rib over the 6 to prevent belt slippage. Hope this helps!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jan 14, 2010 | 11:48 AM
G8GT7's Avatar
thanks all for the help
