How much is install??
If i come to a shop with a full kit how about how much would it be to get it installed?
And what would be smarter moneywise, getting it installed and tuned at one shop, or letting one shop do the install and going elsewhere for the tune?
I dont know if this info is needed but the car is a 2006 and is 6 speed(yes clutch will be upgraded with install)
Yes,have the shop build and tune the car.Then blame can't go anywhere if there is a problem.
Next step is calling around shops i suppose. If its around $3,000 for install and tune i guess i will just install a supercharger myself and go get it tuned at a shop.
Guess this explains the rarity of TT goats however.
Plan on having the car down for a while also. Most shops don't drop everything to do a 30-40 hr install. They take their regular quick turn around work and do yours in between. And if they work on alot of GTO's, you're car could become a parts car when they need something quick. Just saying because I have seen it happen more than once.
On the other hand. If you can use a hammer, a wrench, and a grinder, then you can install that kit. If you have a garage spend $1500 on a lift and do it yourself. If you can't have your car down for work, buy a $500-$1000 beater and sell it when you are done.
The twin turbo setup takes alot more time.If it's a rush job the price goes up to full hourly charge.If the shop gives a decent deal they are ussually losing money doing the job.
Im not sure i would suspect that to be the answer. i would lean more toward to the fact that as of now, there is only TT kit available for the gto. Gen TT. Im not sure the cost of the kit itself, but have heard its salty. SO with that said. Most people i know of who have turbos or superchargers for that matter do the install themselves. I believe it the best choice. IF you can do something like weld then outsource that part. Much easier, and then You get he satisfaction of knowing you did it yourself. THERE IS NO BETTER FEELING! IMHO. Now with that said. Buy the TT kit, and install it. you should be able to handle it. if you cant, get a friend. youll save alot of money man. lots of money for other things like upgraded axles and such.
Nic's website:
This is my first turbo car too, hell this is my first project doing any kind of performance mods aside from intake and exhaust. Man up and get the experience, you cant keep paying a shop to do the work...you gotta learn it sometime! Its so much fun and youll have a much greater appreciation for the car if you do the work yourself
Once you get it all sorted out, there is no better feeling. If it was easy, everyone would do it.
