guess horsepower before dyno Round 2
This is from my original post
Didn't hit the number i was looking for.
347 LS1 engine 5.7, forged mahle dished pistons -16cc, forged eagle H-beam rods, ARP connecting rod bolts, Ported 243 heads, Patriot gold kit, LS9 cam, LS1 intake, ported ls1 throttle body, P1sc(3.3 pulley), front mount intercooler, bosch 42 green top injectors, Longtube race headers, offroad y-pipe, no cats, Magnaflow muffler only, rebuilt 4L60E 2400 rpm stall, walbro gss340 and ngk tr7's. My ported throttle body has a hole in it and is causing my idle to go high. Ran out of injector before i hit 470.24 RWHP 443.80 RWTQ
Added 80lb injectors flow matched, bbk ssi intake and throttle body(already had from another build). Hotwire kit on main fuel pump and second walbro gss340 activated via boost switch under the hood. I block the factory fuel return and installed a front mount regulator with new return line. Also add MMS crank pulley and 3.2 procharger pulley. fuel pressure and boost gauge
