Meth or intercooler or both?
Old Jan 22, 2010 | 06:16 PM
fuzzyjk's Avatar
Default Meth or intercooler or both?
STS Rear mount T67 with 8.5 boost (specs below) Should I plan on running both an intercooler and the meth? I hear boost is addictive so having both might be better when and if I turn up the boost, or am I all wet?
It is a 94 Z, A4.
Rebuilt block 0 mile 355 (stock crank/rods)
re-ported LE Heads
Manley Valves 2.00" Int/1.56"
APR throughout
1.6RR gold
Trick Flow PR
Crane 227
918 springs
ported stock intake
BBK shorty headers
cat delete
egr/air delete
Alt relo-a/c delete
full wrap for exhaust
60lbs injectors
225 fuel pump
STS rear mount
T67 upgrade
8.5 spring
Meth kit
LTCC
New GM remanned tranny
3000 stall
BMR trak pak with adj torque arm
Koni on the corners
Thanx for the advise.
Old Jan 22, 2010 | 06:21 PM
mike13's Avatar
I run both plus I have my AFR on the rich side.
Old Jan 22, 2010 | 06:54 PM
RooRnZ28's Avatar
you should definitely plan on using an intercooler at that boost level... your iat's will be through the roof without one.
also, don't plan on your tranny lasting very long. Get something that has been built for the extra power.
just an observation... but if you're ditching the a/c, why not just do a front mount setup?
Old Jan 22, 2010 | 07:43 PM
fuzzyjk's Avatar
STS= $2,000 for everything, so I figured "why not"
Old Jan 23, 2010 | 01:10 AM
DeltaT's Avatar
IC is the cake, meth is the frosting. Definitely do the IC, meth is great for insurance.
Jim
Old Jan 23, 2010 | 08:08 AM
AFASTYZFR1's Avatar
both
Old Jan 23, 2010 | 11:40 PM
ZLEEPER's Avatar
Originally Posted by AFASTYZFR1
both
especially in hotter climates. Good insurance
Old Jan 24, 2010 | 01:55 PM
Wicked_C5's Avatar
Both!
Old Jan 24, 2010 | 01:58 PM
spaz1's Avatar
I am running both. I had just meth and didn't like it. I installed the procharger intercoolers.Do the intercooler.
Old Jan 24, 2010 | 02:09 PM
elias_799's Avatar
with your CR i would run both an intercooler and meth injection
